Old 06-21-2013, 06:10 AM   #397
Originally Posted by bonox View Post
Hi All
I tried this today on my December 2006 YR. Is there a way to tell if you've made a connection to pin40 on A21? Is there a test resistance to ground or another pin for example?
Mine also does not have the blue wire populated in the fuse box for the clutch switch either. Does this mean it's a no go? There is a pin at the bottom (just not a wire coming out of the plug), which I tried grounding, but couldn't get CC to work.
Thoughts any of you gurus? :)
For the pin 40 test, measure the voltage on the wire with the ignition switch in the on position. You should see 12 V on that pin.
The missing blue clutch switch wire is potentially a bad sign. Did you verify that there was not a connector taped to the harness, just above the clutch pedal?
Old 06-21-2013, 07:56 PM   #398
bonox
Drives: Bronze 07
Thanks Scott
Will check pin potential - didn't look for connector at the time, but I don't have one.
Cheers
b
bonox is offline   Reply With Quote
Old 12-03-2013, 02:14 PM   #399
harda toenail
Drives: Want a yaris
Is the clutch switch required? Is it's purpose to disengage the cruise when the clutch is pressed in?
harda toenail is offline   Reply With Quote
Old 12-03-2013, 02:18 PM   #400
The clutch switch is required for MT cars. The switch works the opposite of the clutch start switch, which is why it is a separate switch. It does disable CC when the clutch is touched, to prevent revving.
Old 12-03-2013, 08:30 PM   #401
harda toenail
Thanks for the quick reply. My dad wants cruise in his 07 MT LB yaris. I'll get the part ordered.
Old 12-03-2013, 09:01 PM   #402
I stock all of the cruise control parts at less than dealer or mail order prices, if you need anything.
Old 02-12-2015, 02:57 PM   #403
Kirill
Drives: Yaris 2009 1.3 sol 100HP
Hi Scott,
I have the 2009 yaris Sol 100HP MMT transmission I will appreciate your help. could you check if it possible to install the cruise control on my car? I can send the VIN number ...
Kirill is offline   Reply With Quote
Old 02-12-2015, 07:11 PM   #404
Originally Posted by Kirill View Post
Hi Scott,
Unfortunately no European made Yaris prior to 2012 had cruise control. It was not until the 3rd generation with the 1.33L engine that Toyota added it.
Old 02-17-2015, 10:00 AM   #405
bronsin
bronsin's Avatar
I installed CC on my 09 Yaris in the summer of 09 according to CT Scotts instructions. It has worked flawlessly ever since.
I work building electronic devices for space and military applications. I told my supervisor about the CC mod in my Yaris and he looked alarmed.
"Paul, I cant BELIEVE you are modifying your brand new car by what some idiot on the internet is telling people to do!"
Old 02-17-2015, 06:05 PM   #406
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I also just finished installing the CC mod on my '09 Yaris according to CTScott's instructions 2 days ago. I am still baffled by how easy it was to enable this function.
Before, when I went to a dealership to ask if they could do it, they said they didn't even want to touch it.
"If it didn't come with it originally, we can't do anything about it." I would love to go back there now and just laugh at their faces.
I'll post some photos once I label all the buttons.
Thanks again CTScott! You are trully a Yaris mod master!
Old 02-17-2015, 06:29 PM   #407
bairjo
Thanks again CTScott! You are trully a Yaris mod master! [/quote]
CTScott is def the man here. He is "THE DON" or should I say "THE SCOTT" of yarisworld. If he ever traded all three of his Yaris prototypes in for some other car...Yarisworld would not be as good as it is today..
Old 05-10-2015, 04:37 PM   #408
1972Dart
Drives: 2007 Toyota Yaris 4dr
Thanks a million to CTScott for all the help on my 07 Yaris! Cruise control works great!
1972Dart is offline   Reply With Quote
Old 05-04-2020, 08:28 PM   #409
Khalil
Hi CTScott
I try to instal CC on my yaris 06 , but it did not work !!
Khalil is offline   Reply With Quote
Old 05-05-2020, 12:39 AM   #410
TcBryan
TcBryan's Avatar
Drives: 2007 yaris sedan base
I have found several at the local pick your part yards.
TcBryan is offline   Reply With Quote
Old 05-05-2020, 12:42 AM   #411
TcBryan
TcBryan's Avatar
CT Scott, I will trade stalks for wire harness for cc.
Old 11-27-2020, 06:03 PM   #412
nowe_service
Drives: yaris 2018
Has anyone installed CCS on the Toyota Yaris 2018 facelift
nowe_service is offline   Reply With Quote
Old 11-27-2020, 10:46 PM   #413
yarisa07hatchi
Drives: yaris 07 hatchi
where can i get ecu wire for cruise and wiring harness for clutch switch help
yarisa07hatchi is offline   Reply With Quote
Old 11-27-2020, 10:47 PM   #414
yarisa07hatchi
where can i get firewall piece i lost it
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
