Old 06-22-2015, 11:57 AM   #397
Originally Posted by shepd View Post
Front end clunk never disappeared after fixing it, though. Guess I have something else to fix... Ball joints and tie rods seem fine. :(
Check your sway bar end links, bushings and control arm bushings. I'm having the same issue on my Echo and i'm gooing to change the bushings next. I'll let you know if it fixes it. The struts, inner and outer tie rods, engine mounts are all new and the strut bearings were both regreased.
Old 06-29-2015, 09:04 PM   #398
kanaga
Drives: '08 yaris sedan
If you're on the fence about replacing these bolts, do not assume that they are OK because the bolt heads look ok. My driver side bolt head looked brand new, but the shaft was in bad condition.
kanaga is offline   Reply With Quote
Old 06-29-2015, 09:07 PM   #399
How'd you end up removing the one w/ the snapped off head?
Old 06-29-2015, 09:10 PM   #400
auxmike
auxmike's Avatar
What's the part #?
Old 06-29-2015, 09:34 PM   #401
kanaga
I jacked up the car and removed both wheels. I then removed all of the bolts holding the crossmember to the car. Then I was able to use a pry bar to pry down the lower control arm and crossmember. This exposed the shaft of the bolt above the bushing. I then used A pair of vice grips to back the bolt out.
Old 06-29-2015, 09:37 PM   #402
kanaga
Originally Posted by auxmike View Post
What's the part #?
90119-14126 or 90119-14151
the second number is supposed to be a replacement for the first, but there doesn't seem to be any difference.
Old 08-03-2015, 11:37 AM   #403
Just some updated info regarding the bolts.
I removed mine the other day to inspect its condition. I replaced them about 10 months ago with new ones and put anti seize on the threads and covered the whole bolt in grease.
I re torqued them without weight on the wheels so I wanted to install them with the suspensions properly weighted and I was curious as to how a very cold and salted winter effected them.
I removed them and there was absolutely no rust on them what so ever. The grease was still all over the bolts but it was a bit more dry. I removed the old grease and put marine grease on them instead thinking it would do an even better job.
After seeing the condition after 1 year I will now be checking these every 2 years instead. I assume that they will last about 6-7 years before I'll need to replace them again.
Old 08-17-2015, 04:14 PM   #404
JTDBT903
JTDBT903's Avatar
Drives: '08 SEDAN 5 SPD.
Took car in for some recall work today and told them about the TSB and these bolts and the guy tells me this TSB is obsolete!
Was this ever a recall for northern USA climates? My car is a 08 sedan with 31k.
Should I just buy the bolts and replace? I only have one winter on her.
JTDBT903 is offline   Reply With Quote
Old 08-17-2015, 06:24 PM   #405
kanaga
Did he say anything about a new TSB that replaced it? I'm pretty sure that the bolts won't just stop rusting on their own.
Old 08-17-2015, 09:12 PM   #406
The update TSB is: T-SB-0078-12
The Canadian one is: T-TCI-3626
Old 08-17-2015, 10:19 PM   #407
JTDBT903
JTDBT903's Avatar
Went back and told him about TSB 0078-12
and he said that is only good for the 3year/36k warranty.
I thought they extended this to 7year/100k?
Also, I got nowhere with corporate Toyota, but I only gave them the Canadian TSB 3271 at the time.
Old 08-17-2015, 10:31 PM   #408
It is 7/100:
Warranty Extension.pdf
Old 08-18-2015, 07:07 AM   #409
I'd just recommend getting the bolts yourself and replacing them, it will save you and your wallet down the road.
Old 08-18-2015, 08:56 AM   #410
JTDBT903
JTDBT903's Avatar
Scott, is that an official document of Toyota?
I called corporate this morning and for the second time I have talked to them they know absolutely nothing about this issue, and without a specific TSB number they were clueless. Both times I feel I was treated very rudely.
This is a safety problem and you think they would be a little more concerned about it!
Anyway apparently my VIN does not fall under this WARRANTY ENHANCEMENT PROGRAM even though my 2008 yaris sedan is clearly included in the vehicles covered. I asked the woman if she was unwilling to help me and she told me to take it up with the dealer.
I am in disbelief as how TOYOTA is treating this issue with me.
Old 08-18-2015, 09:09 AM   #411
Toyota does not have a very good track record of helping people out with manufacturers problems. That being said no car companies really do.
Hence why it's just best to pick up the bolts and do it yourself. The more you know about the Yaris the less you need to rely on others to fix it.
Old 08-18-2015, 02:26 PM   #412
JTDBT903
JTDBT903's Avatar
That's what I'm more than likely going todo. I do all my own work anyway. I just wanted to have some satisfaction as to proving it to the dealer that I was correct with this issue, and also Toyota. I was thinking of getting a new Tundra down the road but not now......
Old 08-18-2015, 02:57 PM   #413
nookandcrannycar
What about a reliable low cost independent shop? Friends who could recommend one? I bought the bolts and had such a shop do mine and it was under $30.00 IIRC...might have even been under $20.00. I've had them do other little things like clean the rear brakes along with adjusting the parking break, etc. They are just insanely inexpensive. They've been in business since 1973 and have two locations. When I think "expensive metros where the cost of everything is 'driven up'...", I think the West Coast, the Northeast, and South Florida....not Texas or NE Ohio .
Old 08-18-2015, 08:25 PM   #414
Yes - That was an official bulletin to dealerships. The updated TSB numbers that I posted above are current and correct.
It is possible that your sedan is not included, as sedans are a different body and are built in a different factory, so they may have the seams sealed that are the cause of the issue.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
