Old 08-04-2012, 10:26 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Had an opportunity to do the water test today.
I taped off the throttle body and hose inlet fittings and filled up the runners while tilting the manifolds around to make certain that there was no captured air. And then I emptied them into a big bucket and poured the water out into a 32 ounce measuring cup.
The results confirmed the obvious... the plenum on the Yaris manifold is much larger than on the Corolla manifold.
Total volume of Yaris manifold 127 ounces
Total volume of Corolla manifold 101 ounces
This makes the total volume of the Corolla manifold about 20% smaller, even though it was designed to flow for an engine with 20% more displacement.
And I have absolutely no idea how this will affect the performance...
...but I'll find out soon.
Old 08-05-2012, 09:40 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
In my research, I was never able to find conclusive evidence of how the volume of the plenum affects the power curve. It would be better if you could measure just the volume of the runners, but that might be tough since you can't really see where the Yaris runners meet the plenum.
My guess is that the Yaris uses a much larger plenum to reduce the effect of the air entering perpendicular to the runners and provide adequate "reserves" for the runners farther from the TB. I haven't entered a guess yet, but I think the net result will be a shift of peak HP/tq RPMs that is more significant than the change in peak overall.
Old 08-05-2012, 11:30 AM   #3
tooter
play every day
tooter's Avatar
I can see the first runner in the plenum...
... but there are internal undulations which prevent seeing the others, and I think there's also some kind of chamber in there because the water was captured in the plenum and I had to tip it around all crazy sorts of ways to eventually get it to come out.
Yes. From what I've read, there are issues with the mouths of the runners being perpendicular to the flow of air entering the plenum. Also there are issues when the runner mouths are not raised above the edge of the plenum.
The Corolla manifold gets around that, first ,by having the intake from the throttle body entering into the exact middle of the plenum, which, from what I've read, is a significant design advantage over having the entry at one side putting all of the runners at different distances from it.
And, second, all the runners are only 2 1/2 inches away from the central entrance point and are all equidistant from it, and all "looking" directly at it, so there is no change in the direction of the flow. This design is similar to a backwards flowing exhaust header.
I really like this design as it is a complete departure from the typical perpendicular runner "log" style manifold.
I've been reading about another manifold principle in play called resonance. Sound waves created by the valves slamming closed travel back up the runner and are reflected back to the valves by the plenum. This tuning can pressurize the incoming flow as it enters the valves providing a supercharging effect. These sound waves travel back and forth many times even within one valve cycle. So the plenum is a kind of echo chamber, and the size determines the frequencies of rpms that it favors. This principle is somewhat like the principle of exhaust scavenging which uses resonant pulses of adjoining runners to draw the exhaust down the header.
I agree, as my guess is just a very slight positive and negative change in hp and tq. At what rpm frequences this manifold resonates is unknown...
...but they will be clearly revealed in the graphs of the dyno runs.
Old 08-04-2012, 10:38 PM   #4
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
cant wait to see :)
Interior:ALL red, black roof
Old 08-05-2012, 05:25 AM   #5
My personal opinion, peak hp and torque changes will be minimal and could be attributed to the margin of error of the dyno itself. But, I think there will be less low and mid-range torque.
so...
+0hp +0tq, weaker midrange
Old 08-05-2012, 08:20 AM   #6
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Shit id pay 700 for RHs manifold for those kind of gains...and what looks to be on the stock airbox too
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-05-2012, 09:12 AM   #7
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Garm is onto me...hehe
-Type 07 FFL-
My odometer 03/11
Old 08-05-2012, 02:25 PM   #8
we'll never know why a Yaris intake manifold couldn't be produced for $700 a unit.
That's an easy one.
1. R&D cost required to prove that a manifold works, produces power, and causes no CEL's.
2. Utter lack of Group Buy interest in terms of real deposits, when #1 is unknown.
Just look at the Weapon R manifold (which is $700 by the way), and the nearly zero sales it generated for the xB market.
But hey... someone's gotta do it.
Old 08-05-2012, 03:28 PM   #9
tooter
play every day
tooter's Avatar
That's an easy one.
From reading the old thread, Richard had a dynoed working prototype that produced significant gains.
More than 10 people were on the buy list which he said was the threshold for a production run. After a long gap of no communication, people got discouraged and dropped out when nothing happened.
Wow, I didn't know that they actually came up with a Scion product. Have to take a look at it.
Looks like the torch has now been passed on to me.
Today makes exactly two months elapsed time to produce one tooter prototype that's ready to bolt onto the engine...
Old 08-05-2012, 09:13 PM   #10
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Then go bolt that sucker on!!!!
Old 08-05-2012, 10:40 PM   #11
3cyltrbo
if:
-this makes power (fantasizing about 5whp)
-and / or if it changes the intake noise
AND
its not $700 (assuming tooter was to produce them)
I'd be on it like a fat kid on cake
like michael jackson on little boys
like the republicans on helping their rich chronies
like michael phelps on gold medals
(Cliffs notes: if it makes power / and or sounds better = Will wants one)
3cyltrbo is offline   Reply With Quote
Old 08-06-2012, 12:12 AM   #12
tooter
play every day
tooter's Avatar
I'm itching to do just that... but I'm also up to my neck in work making money so that I can afford to play with this project in my spare time. This week is especially busy, but I'll try to get it going as soon as I can.
Next up is customizing the intake to fit the new location of the throttlebody, as well as relocating all of the hoses to fit their new locations.
Old 08-05-2012, 02:27 PM   #13
confusion over the volume of the plenum came in--none of the calculators seemed to care about it--and some calculators even seemed to be based on the runners alone.
No confusion there. The calculators don't need a volume number for a reason.
Old 08-05-2012, 03:00 PM   #14
CrankyOldMan
Well, my confusion was based on the incorrect assumption that the plenum became a secondary resonator for the back-pulse.
Old 08-05-2012, 03:09 PM   #15
tooter
play every day
tooter's Avatar
If that's true, then it's all for the best because there's almost no plenum on the manifold to resonate anyways.
Old 08-05-2012, 10:42 PM   #16
On a plus side for the cable throttle crowd, we don't need the TB adapter, just the flange for the head.
Old 08-05-2012, 10:48 PM   #17
malibuguy
Obsessed with 1.5L
700 for proven significant gains on a already very effecient motor is chump change. I would buy one in a heart-beat and any true motor head that understands this would too
-96 Tercel 4dr
Old 08-06-2012, 01:51 AM   #18
ljming99
Drives: Yaris '06
Well, do remember to keep any changes to the hoses documented. It would be a plus when this becomes a complete kit.
Anyway, i ever though of getting the weapon r and then customising it to fit a yaris...but that would be spending insane amount of money ...and i wouldnt wanna risk spoiling a sexy bling bling weapon r manifold.
Anyway, you are paying for the bling bling "exotic" material for a weapon r manifold.
They could have kept cost down, at least get from profit for making an affordable manifold made of common material =P
ljming99 is offline   Reply With Quote
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
