Old 10-30-2008, 04:33 PM   #37
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Originally Posted by at3GG View Post
How much should a custom cat to axle exhaust run from a decent shop anyway?
Around $200-$250 depending on what muffler and tip you use.
If you use a turbo muffler and no tip you could probably get it under $200.
Old 10-30-2008, 04:49 PM   #38
+1, I got my first custom one done for $280 in Van Nuys.
Old 10-30-2008, 07:39 PM   #39
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
Originally Posted by largeorangefont View Post
The foulers do the same thing but mechanically. You are reducing the amount of exhaust gasses the sensor is exposed to, and skewing the reading. Some cars need 2 of them to keep from throwing CELs, one drilled for the sensor, and one undrilled.
ok so you finally got in your head what ive been saying except for the fact that even with the double fouler method that CEL still comes on. NO, who on here is running this setup and has no light.......
Old 10-30-2008, 08:42 PM   #40
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
no CEL!
Old 10-30-2008, 08:44 PM   #41
Malaya, in 40 years when your car has over 5 million miles on it, you'll get a CEL -- Rockland knows.
Old 10-31-2008, 09:56 AM   #42
largeorangefont
Break'em off some.
See post #48.
Old 10-31-2008, 10:42 AM   #43
I have this midpipe... since just about a year... and not a single CEL...
Truth be told I am quite sure the USDM ECU is way more stringent on the emissions stuff, hence the trouble you've all been having :fronw:
Old 10-31-2008, 12:04 PM   #44
ROCKLAND TOYOTA
TRIM HUNTER
Originally Posted by Malaya1221 View Post
no CEL!
yeah cause you just put this on a week ago or so correct???
Old 10-31-2008, 12:05 PM   #45
ROCKLAND TOYOTA
TRIM HUNTER
See post #48.
see post 51
Old 10-31-2008, 12:13 PM   #46
largeorangefont
Break'em off some.
see post 51
That post would be great if it were correct. Again, that 02 sensor is just there to verify the cats are working.
Old 10-31-2008, 02:30 PM   #47
Malaya1221
Malaya1221's Avatar
had it b4 for 6 months WITHOUT CEL turning on till WEAPON R header broke!
Old 10-31-2008, 03:20 PM   #48
ROCKLAND TOYOTA
TRIM HUNTER
awww should have done that right the first time.....
Old 10-31-2008, 03:41 PM   #49
Malaya1221
Malaya1221's Avatar
i forgot you're an expert on YARIS! the CEL will turn on in 40 years, but 4 now i should be happy with CEL off!
Old 10-31-2008, 04:14 PM   #50
ROCKLAND TOYOTA
TRIM HUNTER
hey, if you want to call me an expert for installing parts back on correctly then so be it....
Old 10-31-2008, 06:32 PM   #51
Malaya1221
Malaya1221's Avatar
kuro, forget garm! u might want to ask rockland(our yaris in-house expert) about your CEL turning on he will definitely know the answer to that!
Old 10-31-2008, 06:38 PM   #52
kuro, forget garm!
Malaya !!!
Old 10-31-2008, 06:46 PM   #53
Malaya1221
Malaya1221's Avatar
apologize for the offtopic:
cali_yaris, i don't think you know what you r doing, from now on i have rockland to solve my yaris problems!
hey kuro, did you install the oem bracket to the dc header?
Old 10-31-2008, 07:47 PM   #54
Malaya1221
Malaya1221's Avatar
^ keep us updated!
Check engine light on kcty DIY / Maintenance / Service 19 03-10-2012 08:54 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
Check Engine Light Question falkor_99 General Yaris / Vitz Discussion 11 07-22-2007 05:15 PM
