Old 12-17-2008, 08:46 PM   #37
Klink10
Klink10's Avatar
Got mine (Blitz TC), haven't had time to put it in yet. To many other mods happening.
Old 12-17-2008, 08:52 PM   #38
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
you will love it. i did!
Old 12-17-2008, 09:00 PM   #39
Klink10
Klink10's Avatar
Where did you mount the brain box on your install?
Old 12-17-2008, 10:36 PM   #40
Free Fly
Free Fly's Avatar
Drives: Black Sand Pearl lift back
I was under the empression that the yaris came with self learning technology. Anotherwards if your looking for mpg break it in that way. If your gonna run the crap out of it break it in that way. I broke my 06 scion xA for mpg and it couldnt get out of its own way. I have been running the crap out of my 08 yaris and it never lets me down. I have never had my yaris choke up on me. Is this possible or am i stuck in a time dialation bubble?
kms2112
Free Fly is offline   Reply With Quote
Old 12-18-2008, 01:02 AM   #41
mikenacarato
SIPNDEW
Drives: 15 STI
thats how i broke mine in. i plan on driving it hard so why wait to "break it in"?
klink- i mounted my main box under the steering wheel inside the dash. pull down the bigger cover under the wheel and from there run the wires to the pedal and then run the wires to your display, which i have inside my drivers glovebox.
Old 12-18-2008, 07:41 AM   #42
Klink10
Klink10's Avatar
Mike.......thanks.
Old 12-18-2008, 11:07 AM   #43
mikenacarato
SIPNDEW
Drives: 15 STI
NO PROB
Old 12-18-2008, 12:37 PM   #44
TheSilkySmooth
TheSilkySmooth's Avatar
Originally Posted by largeorangefont View Post
It is more pronounced in the auto because you wait for the throttle to respond, there there is a delay while the transmission downshifts.
Throttle response is SHARPER than on my cable linked cars. There is a lot going on in the ECU, not just throttle response. It will not go WOT if revs are low or timing retard due to ping/knock sense. Best thing you can do is keep the carbon off the piston tops (wail it and water it) and slippery oil in the cranckase with a real 88-90 ocatane quality fuel toikeep the timing at max adavance at low rpm; then it should be locked and loaded all times. This ecu will learn a FE mode due to driving style then you punch it and it says - FU guy! <or> THE SOLUTION: Take off the F.I. and put a string of Mikuni 28MM. from a crashed Suzuki 1000 cc GSX-R
- bro
Old 12-27-2008, 06:11 PM   #45
AznGouki
Metsu
Drives: NCP91 ; E36
Damn..I'd like a cheaper alternative though. 4 bills is too much. I'll try the nst pullies first.
AznGouki is offline   Reply With Quote
Old 12-27-2008, 08:13 PM   #46
mikenacarato
SIPNDEW
Drives: 15 STI
the pulleys did make a good difference. but when i added the controller afterwards...theres no comparison.
Old 12-27-2008, 08:14 PM   #47
ChinoCharles
Drives: LB
That controller probably improves track times quite a bit, eh?
Old 12-27-2008, 11:05 PM   #48
mikenacarato
SIPNDEW
Drives: 15 STI
not sure. i would imagine if your track was twisty than coming out of turns would improve.
Old 12-28-2008, 06:03 AM   #49
ddongbap
So I don't get it. Does this thing actually eliminate the delay? Or does it provide 90% of the throttle, during the first 10%, WITHOUT eliminating the delay?
Old 12-28-2008, 03:40 PM   #50
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
+1
ztrack157 is offline   Reply With Quote
Old 12-28-2008, 05:00 PM   #51
mikenacarato
SIPNDEW
Drives: 15 STI
it eliminates delay. the response is very quick now.
Old 12-28-2008, 06:15 PM   #52
dybbuk
dybbuk's Avatar
Drives: 2008 Yaris HB
what i meant was the lag may exist on auto but manual is very responsive depending on what revs ur on..
I would say the same thing about my auto. If I'm driving conservatively(i.e. most o the time and punch it, there's a delay. IF I'm racing around town and keep the revs up the response is sharp as it can be.
dybbuk is offline   Reply With Quote
Old 01-02-2009, 01:06 AM   #53
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Yeah I have this problem too, especially while trying to pick-up speed while entering or transitioning freeways. I have to shift down one more gear to match the traffic speed and prevent a wreck, at the expense of temporary engine strain.
DBC conversion sounds good right about now
Old 01-02-2009, 01:29 AM   #54
Klink10
Klink10's Avatar
Finished my Blitz today and went for a test drive. All those problems are solved. I couldn't stop driving it....TC makes it a whole new car.
DIY: Replacing Stock Mirrors redyaris DIY / Maintenance / Service 30 04-20-2016 03:03 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
ICE Navigation Wire Question? duck In Car Entertainment + Electronics (audio / video / alarm) 11 10-25-2008 12:20 AM
kicker 1/0 gauge wire installed... punch In Car Entertainment + Electronics (audio / video / alarm) 1 07-25-2007 07:46 PM
