Old 12-05-2010, 09:00 AM   #37
Klink10
Klink10's Avatar
Just changed mine out last week after 15K. I attribute it to several factors which may or may not have been my fault. In either case I went to a discount OEM parts supplier and got one for $76.00. Did the work myself and changed up my NST pulley install procedure. I really do think that the weakest point on the Toyota waterpump is the seal around the bearing and that care should be used in the removal/install of the pulley and the tightening of the belt. I do know that Toyota offers no additive to the coolant used (Toyota Pink) in the Yaris. I also know that Toyota had 2 types of coolant and some dealers or whatever may still have the obsolete (Toyota Red) still around. The red is straight while the pink is a pre-mix. For info, if you look at the back of the "pink" jug it says that if you flush use only the "pink" to flush with and not "any kind" of water. The logic I assume is that you can't get all your flush out and thus would be dilluting your new stuff. Personally, after having read other stories I took it to heart and went with their advise. I know others have done it different and seem to be doing okay. Me, this is the way I went.
Old 12-05-2010, 10:25 AM   #38
DARK AGE 53
Drives: 2009 Yaris Onyx
if the water pump is covered under the drivetrain warranty then I'm good for life, hopefully I won't have to find out.
DARK AGE 53 is offline   Reply With Quote
Old 12-18-2010, 05:25 AM   #39
budzrsi
Drives: yaris T1
Hi guys! Anyone knows whether there suppose to sealant applied after the pump is changed? Cos it did come wid an o-ring.
budzrsi is offline   Reply With Quote
Old 12-18-2010, 08:38 AM   #40
Klink10
Klink10's Avatar
No sealant supplied. The service manual which I used as reference mentioned no sealant either. Didn't use any. Mine is an 07.
Old 03-03-2011, 02:11 AM   #41
birdman
Nice write up so now I know where to watch for crystal formation.
Old 03-15-2011, 07:33 PM   #42
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
my hood looked like that but not pink. not sure how long it has been out, but the squeaking is getting worse...like much worse.
Club SHIFT
Old 03-15-2011, 07:56 PM   #43
auxmike
auxmike's Avatar
Originally Posted by kou View Post
Maybe just the way the belt is tensioned from the factory.
Yeah, I tried to match that factory setting by marking the position with a sharpie when replacing the old pump and I could'nt pull hard enough to even get it THAT darn tight!
I got it close to the factory "mark", and the new pump went about 2k before it started spritzing again....
I check the "new" (2nd) pump almost daily, it only spritzes very little every other day, it's been that way since Xmas. Mabye I'll install a 3rd new pump once the weather improves (I have an AC Delco unit stashed)
Old 06-27-2011, 04:15 PM   #44
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
looks pretty simple thinking of getting ac delco water pump might be better than toyota..i just dont get how to drop your engine 2 inches..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 06-27-2011, 04:23 PM   #45
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
NOT A CHANCE 3/36
ROCKLANDTOYOTA is offline   Reply With Quote
Old 06-27-2011, 07:12 PM   #46
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
+1
I removed the bolts from the motor mount, but the motor didn't go anywhere. Even with the jack not supporting it at all....
goliath1812 is offline   Reply With Quote
Old 06-27-2011, 07:21 PM   #47
auxmike
auxmike's Avatar
Here's my Delco pump and FelPro gasket I keep handy....
Old 06-27-2011, 07:25 PM   #48
marcus
toyota
marcus's Avatar
thats exactly what i want on the yaris..looks more durable than oem!!
Old 06-28-2011, 09:40 AM   #49
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
WHY does the 2 gaskets in the last picture look different??
Old 06-28-2011, 10:12 AM   #50
Put a jack under the oil pan and undo the passenger side motor mount.
Old 06-28-2011, 10:46 AM   #51
marcus
toyota
marcus's Avatar
i re read his post over looked removing SIDE MOUNT!!!!!!!!!!! now what side mount is he talking about???
Old 06-28-2011, 11:21 AM   #52
auxmike
auxmike's Avatar
Because I bought the felpro separately.I also have a new metal oem one.
Old 06-28-2011, 11:46 AM   #53
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
must be how im looking at it but they do look DIFFERENT....
Old 06-28-2011, 12:11 PM   #54
Common man, there's only 3 mount on the engine, and I don't think you're going to remove the one on the transmission side.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY Requests. TinyGiant DIY / Maintenance / Service 13 10-29-2008 10:39 AM
