Old 05-31-2009, 04:40 PM   #37
Penguin Garage
Penguin Garage's Avatar
Originally Posted by TheRealEnth View Post
GIMMIE MY STICKERZ!!1111
whoa, yelling isn't going to make USPS go faster. haha.
although Tamago has a stack of White Ones for the South Florida Yaris Peoples. :)
Penguin Garage is offline   Reply With Quote
Old 05-31-2009, 07:24 PM   #38
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Nice diy I'll have to pick a pair of these up when i get paid.
Old 06-02-2009, 01:28 PM   #39
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
Special Torque setting? As in do I need a torque wrench to do this simple procedure correctly?
Bob Dog is offline   Reply With Quote
Old 06-02-2009, 01:41 PM   #40
Tamago
Tamago's Avatar
Drives: UZJ100
if you want to torque the bolts, you'll need a torque wrench. however, "tight" isn't very hard to achieve :)
Old 06-05-2009, 06:16 PM   #41
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Got mine a week ago. Put them on today and I'm digging the new look Sorry for not taking before and after shots, but that's just how I roll. Hardcore, no pics.
Anyhow, the install was a breeze though I suggest when pulling the drum that you use those two screw holes provided. I tried prying it off a couple of different ways but didn't want to damage the back plate or anything else for that matter so the bolt in the hole did the trick. I just happened to have a small bolt that was perfect for it though I don't know the thread size. Just torqued on one hole til it started to pop off then did the opposite side. Piece of cake.
Easy mod for a beefier looking back end. Haven't taken it through any turns to see if it makes a huge difference in handling, but given that the change is very noticable to the eye I would expect some extra stability out of it.
I highly recommend this mod. Thanks Penguin Garage and Tamago!
Old 06-05-2009, 06:55 PM   #42
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
size of that bolt would definetely come in handy...i do use bolt to pry out the rotor as well if its stuck on the hub. makes is alot easier..and thats what those 2 or 3 small holes are for.
Old 06-13-2009, 06:49 PM   #43
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Where on the drum are you tapping with the hammer? Are you using a screwdriver as well to help pry it off?
marlondog is offline   Reply With Quote
Old 06-13-2009, 07:06 PM   #44
Tamago
Tamago's Avatar
Drives: UZJ100
i've never had this issue, as i remove my drums every time i remove my rear wheels (simply to keep the corrosion factor to a minimum) however there is a small slot between the drum and the backing plate. you should be able to stick the corner of a block of wood (or a brass/copper punch) in this groove and go to town.
I apologize that i have not yet posted the bolt spec for pushing the drum off of the hub. my guess is that it's a standard metric bolt (coarse thread) that has a 10mm thread. 8MM possibly? i'll definitely let you guys know my findings, i'll be doing new rear brake shoes soon.
Old 06-14-2009, 12:01 AM   #45
marlondog
marlondog's Avatar
Finally figured it out. It looks dope!
Old 08-04-2009, 06:13 AM   #46
Tamago
Tamago's Avatar
Drives: UZJ100
edited. i added the ABS plug removal bit, stolen from the factory svc manual.
Old 12-25-2009, 04:54 PM   #47
advocate
Drives: car
Alright just got the spacers in. My kit didn't come with a penguin either but I did have camber shims and lube.
I'm worried about my brakes though because they're not as responsive as before. I noticed a big difference after putting in the spacers and braking. It's somehow related to the brake lines because they had to be stretched a little bit to reach the hub after it was spaced further from the car.
Old 12-25-2009, 05:35 PM   #48
YarisSedan
Drives: 08 Yaris Sedan
You should have any issues. Its possible you may have slightly kinked a brake line. You could try adjusting your rear brake shoes to see if helps.
Old 12-25-2009, 06:07 PM   #49
YAR1S
YAR1S's Avatar
I hate to say this but maybe a re-think on the sticker design is in order.... my penguin's beak got ripped off today after carefully sticking and re-sticking everytime I wash my car...... poor thing is this blobb animal now.... :(
-Jen <3
Old 12-25-2009, 06:09 PM   #50
YAR1S
YAR1S's Avatar
Tapping of the drum isnt really nessacary.... luckily the drum has two screw holes that take care of popping off the drum.... I thought I posted this already?
-Jen <3
Old 12-27-2009, 06:12 PM   #51
Penguin Garage
until we do a re-design I can send you a fresh one. :)
what color do you want?
Old 12-27-2009, 06:13 PM   #52
Penguin Garage
Who did you get them thru?
Shoot me a PM I'll get one sent out to you.
Old 02-24-2010, 03:43 PM   #53
Dj_SloKid
Dj_SloKid's Avatar
Drives: Yaris Sedan
Send a message via AIM to Dj_SloKid Send a message via Yahoo to Dj_SloKid
what is the hub spacer for anyways? ikno ima noob
Dj_SloKid is offline   Reply With Quote
Old 02-24-2010, 03:51 PM   #54
Tamago
Tamago's Avatar
Drives: UZJ100
www.penguingarage.com
hub spacers effectively lower your rear offset, making the rear track wider.
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Gauging interest on hub spacers for the yaris Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 61 05-22-2009 02:18 PM
Rear Spacers... (Who sells them?) Saggio General Yaris / Vitz Discussion 6 02-06-2009 08:40 AM
Installing a rear window defroster trn9 DIY / Maintenance / Service 0 01-06-2009 02:56 AM
