View Poll Results: Would these interest you ,if so what offset
0.5 Deg Camber 4 17.39%
1.0 Deg Camber 3 13.04%
1.5 Deg Camber 5 21.74%
2.0 Deg Camber 6 26.09%
2.5 Deg camber 3 13.04%
Good idea , but no thanks . 9 39.13%
Multiple Choice Poll. Voters: 23. You may not vote on this poll
Old 07-12-2009, 03:12 AM   #37
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
I was running negative four degrees camber on my fronts, so why only the mild options?
It's not what you drive, or how much $$ you throw at the car. Mod the ballast on the front left first!
anonymous user is offline   Reply With Quote
Old 07-12-2009, 03:56 AM   #38
1NZYaris1
1NZYaris1's Avatar
very simply because there is no demand , and the set up cost's ,
would be more than what anyone would pay for them.
But if you really want 4 degrees , i would be more than happy to
make a set for you .
Old 07-12-2009, 07:56 PM   #39
MUSKOKA800
MUSKOKA800's Avatar
Offhand, can anyone advise the factory rear camber setting for an '08 sedan?
Old 07-12-2009, 08:20 PM   #40
1NZYaris1
1NZYaris1's Avatar
yep factory camber is set just under 1.degrees (0.97 +- 0.75)
if you want you can check it yourself by looking it up in the
http://www.yarisworld.com/forums/showthread.php?t=1768
look under the Suspension PDF
Old 07-12-2009, 09:11 PM   #41
Penguin Garage
Penguin Garage's Avatar
The reason we didn't do the camber added spacers was this exact reason. Far too many options which would increase the overall cost/retail price of the product. Since a shim/washer can achieve most camber settings.
be glad to help if i can.
Penguin Garage is offline   Reply With Quote
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Gauging interest on hub spacers for the yaris Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 61 05-22-2009 02:18 PM
looky who's getting hub spacers next! Tamago Off-topic / Other Cars / Everything else Discussions 5 05-18-2009 10:19 PM
15 dollar hub spacers ebay... YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-20-2008 01:24 AM
