View Poll Results: Would these interest you ,if so what offset
0.5 Deg Camber 4 17.39%
1.0 Deg Camber 3 13.04%
1.5 Deg Camber 5 21.74%
2.0 Deg Camber 6 26.09%
2.5 Deg camber 3 13.04%
Good idea , but no thanks . 9 39.13%
Multiple Choice Poll. Voters: 23. You may not vote on this poll
Old 06-27-2009, 05:45 PM   #1
1NZYaris1
1NZYaris1's Avatar
Cambered Hub Spacer's , Interested yes / no
Hi Guy's and Girls
If these where on offer , would you be interested , would you purchase
The following fiquires are worked out from a 24" wheel size
http://www.yarisworld.com/forums/showthread.php?t=5021
The fiqures below show the wheel movement (offset) at the
top - and bottom + of the wheel, Relivant to the hub camber angle.
Proposal is this 12.5mm thick spacer's with possably the following cambers
--------------------Bottom -------Top
0.5 deg camber +2.66mm -2.66mm
1.0 deg camber +5.32mm -5.32mm
1.5 deg camber +7.98mm -7.98mm
2.0 deg camber +10.64mm -10.64mm
2.5 deg camber +13.30mm -13.30mm
This is an interest only thread , and if there is enough interest , they
will be put into production , and sold by a Regestered Vendor.
Old 06-27-2009, 06:01 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
sounds familiar. looks familiar. the first pic looks like something i sold in the past. and i think you mean 12.7mm lmfao
Old 06-27-2009, 06:04 PM   #3
1NZYaris1
1NZYaris1's Avatar
Made those 6 weeks ago , kiwi's can do any thing .
And no the material is 12.5mm Marine alloy
also made some 10mm ones
Old 06-27-2009, 07:20 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
Made those 6 weeks ago , kiwi's can KNOCK OFF any thing .
good for you buddy
Old 06-27-2009, 07:34 PM   #5
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
I voted it a good idea but no thanks since that was his previous design of the spacers that he made, but has a new revised one now. Maybe if you buy his new set and try that design instead?
Old 06-27-2009, 07:36 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
my question to the OP is.. are you going to take out the dangerous toe in/out issues associated with camber +spacer setups?
Old 06-27-2009, 07:40 PM   #7
1NZYaris1
1NZYaris1's Avatar
This design is a direct copy of the hub , Tamago's design is muti fit
Yaris , and Xa , Xb i beleave , of which i donot have one to test fit ,
and develope .
Old 06-27-2009, 07:41 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
and develope .
i'd love to see these fit on an xB and xA
Old 06-27-2009, 07:42 PM   #9
1NZYaris1
1NZYaris1's Avatar
and you are, have?.
but yes that can be done as well , if there is enough interest
Old 06-27-2009, 07:43 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
and you are, have?.
xA/B is completely different. this is why the Yaris spacers are unique. and apparently now knocked-off by you (the main reason i went back into production)
Old 06-27-2009, 07:53 PM   #11
1NZYaris1
1NZYaris1's Avatar
Yes me bad , should have put Scion xD instead of xA/B, sorry.
AS Stated above this is a feeler thread , not a for sale thread
But as far as knocking of your design, i pm you for your help 8 weeks ago and you told me too piss off , so i have made my own ,by copying my hub and nothing else.
And as for knocking off your design how is that different to you knocking
of the inner guard brace's Garm is selling.
Old 06-27-2009, 07:55 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
huh? i have no idea what you're talking about.
i did not tell you to piss off. want me to post the PM's ?
Old 06-27-2009, 08:18 PM   #13
06silveryaris
Drives: 2006 yaris
You can easily make camber adjustmens in the rear by using chims or washers instead of changing hubs if you want to keep the factory offset
06silveryaris is offline   Reply With Quote
Old 06-27-2009, 08:21 PM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
yup
http://www.yarisworld.com/forums/showthread.php?t=19450
and those who have a bench grinder can obviously DIY this (but seriously, who wants to grind washers by hand?)
Old 06-27-2009, 08:33 PM   #15
06silveryaris
Drives: 2006 yaris
Well it is time consuming but with thin washer just go adding as needed till your desired degree is reached.
Old 06-27-2009, 08:45 PM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
absolutely.
Old 06-27-2009, 09:17 PM   #17
1NZYaris1
1NZYaris1's Avatar
yep it probably is ,and this is just another possability, too save on that .
thank you for your comments.
Old 06-28-2009, 12:58 AM   #18
The hub spacer itself is not a new invention. Surely Tamago got the idea of using hub spacers from some previous version that someone else made (for another car, obviously). No one criticized him for adapting them (copying the invention, in a sense) for the Yaris, and it wouldn't be right to do so.
These hub spacers seem to have a unique feature (built-in camber). Whether or not you like the idea, it is original and different than Tamago's approach using washers.
So back to the point of the thread - do you like the idea?
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Gauging interest on hub spacers for the yaris Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 61 05-22-2009 02:18 PM
looky who's getting hub spacers next! Tamago Off-topic / Other Cars / Everything else Discussions 5 05-18-2009 10:19 PM
15 dollar hub spacers ebay... YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-20-2008 01:24 AM
