Old 05-14-2010, 07:42 PM   #1
Originally Posted by PhillyG View Post
im a little confused.. i want mine to be looking factory. but is there any one place online to buy all this instead of a dealer? just looking for a little cheaper is all.
TRDsparks.com typically can save you a few dollars versus your local dealer. Buying parts from a junkyard or shopping eBay will net you an even better price for the stalk.
Old 05-18-2010, 09:02 PM   #2
dingbat
Drives: '10 3D Liftback
Did this mod today on my '10 3 door hatch with base trim.
-All harness wires were already in place. No running wires was necessary.
-Screws to remove the airbag were Torx T30. I used a 1/4" drive bit on a ratchet handle with an extension which fit in the access hole very nicely.
-Blade connector for the horn had a little tab locking it in place that caused me some consternation until I realized it was there.
-Ether the switch I got had a scratch on it when I got it or I scratched it when I passed it behind the metal steering wheel frame to set it in place. I'd suggest being careful with that step.
-I didn't disconnect the air bag, just held it out of the way. Only tricky part was drilling the hole.
Exceptional tutorial PeteZNY. Thank you!
dingbat is offline   Reply With Quote
Old 05-23-2010, 09:28 PM   #3
YarisGoFar
Drives: '10 Yaris 3Dr LB, MT Meteorite
I installed it on my 2010 3 LB MT today. I decided to go with the factory steering wheel cover rather than drilling my own hole on a car that has less than 3k miles on it. The steering wheel came off easily with just a slight tap on the wheel with the heel of my hand after removing the nut. Including the clutch switch, it took me under an hour working very carefully and meticulously. Afterall, it's brand friggin' new. Anyway, it works like a champ and I never would've tried it without the help of this site and these pics. Anyone with a modest amount of mechanical aptitude can do this with patience and care.
THANKS! This site and you guys ROCK!
Next up, find someone in South Jersey to do paintless dent removal on the two friggin' door dings on my drivers door that Good thing I don't have the temper I once had...
Anyone know who is reputable in South Jersey that does PDR?
Thanks.
YarisGoFar is offline   Reply With Quote
Old 05-23-2010, 09:50 PM   #4
PhillyG
Drives: 2009 Yaris
AMen Brother! that is why i am waiting on my parts to arrive! even with only 9k on mine... worth it to me to have it factory looking if i ever do have to take it to the stealership!
PhillyG is offline   Reply With Quote
Old 05-26-2010, 04:38 PM   #5
PhillyG
Drives: 2009 Yaris
got my parts! did the install! looks factory! it works! many thanks to everyone!
Old 05-26-2010, 05:19 PM   #6
Revsson
Congratulations!
Old 05-27-2010, 07:20 AM   #7
YarisGoFar
Congrats! Boy did I miss cc. My 90 mi round trip commute up and down the interstate is soooo much easier!
Old 05-30-2010, 03:13 PM   #8
Soner
Send a message via Yahoo to Soner
This question is for everyone who installed the cruise control. How did you guys remove those screws that is removed by using the #27 torx? Those screws are so tight it is impossible to loosen them.
On DIY it's not even mentioned how to take the steering wheel apart other than use #27 torx to remove the airbag. I guess no one else had this problem. Parts of my palms are all red b/c of forcing it too much. Am I doing something wrong?
Soner is offline   Reply With Quote
Old 05-30-2010, 09:26 PM   #9
On my 09 the airbag screws came off easily with a 1/4" drive socket torx bit. I initially tried the torx bit with a screwdriver, but couldn't break them loose. The extra leverage of the 1/4" ratchet was more than enough.
Old 05-30-2010, 09:43 PM   #10
Soner
Can you put a picture of the part you are talking about? When I googled it, I couldn't figure out how I can use it together with the #27 torx I got from Sears.
Old 05-30-2010, 10:44 PM   #11
Old 05-30-2010, 10:47 PM   #12
If you bought a T27 1/4" screwdriver bit, you can make a DIY version of the above, by sticking the bit in a 1/4" socket and wrapping it with tape so it doesn't just fall out.
Old 05-31-2010, 01:27 PM   #13
Soner
OK thank you very much. Let me try that.
Old 06-01-2010, 08:21 AM   #14
PhillyG
Drives: 2009 Yaris
i used a socket torx bit... just what i had.. worked great.. as for remvoing the steering wheel... once you have the airbag out of the way.. and MARKED the alignment of the wheel and post... i just wiggled gently but firmly (dont damage the clockspring) and the wheel came loose with only a minute of wiggling.
Old 06-11-2010, 09:05 AM   #15
PhillyG
Drives: 2009 Yaris
just got back from a trip to florida.. cruise is fantastic.! worked flawlessly
Old 06-18-2010, 02:35 PM   #16
CB900F2
Drives: 08 Sedan
Hye guys... I want to install the CC on my 08 CND Sedan and I am wondering if anyone has a template as to where to punch/cut the hole for the stalk on the cover?
My wife would be very upset with me if I make a bo bo
thanks guys!
CB900F2 is offline   Reply With Quote
Old 06-18-2010, 03:06 PM   #17
I purchased my stalk off ebay along with a Scion Tc steering wheel.
This is what the OEM hole looks like:
There was a rubber bushing that mounted over the fins, which fit tightly around the stalk and flexed as the stalk moved:
I mounted the bushing to my rear cover and then used the center of it as my drill guide (I drilled a 1" round hole, rather than trying to duplicate the square one:
Before I installed the bushing I scanned it. Here's a PDF of it. Print it without scaling and it will print a perfect one. You can either cut one out of rubber, or just use the paper one as your template:
Cruise bushing.pdf
Old 06-18-2010, 10:03 PM   #18
Revsson
Hmmm....first mistake, it's boo-boo!
http://dictionary.reference.com/browse/boo+boo
CTScott is the man...he'll get you all kinds of info.
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
How difficult is it to install the aftermarket cruise control kit? grampi Performance Modifications 3 07-19-2007 08:06 AM
