#37 |
![]() ![]() Drives: 2009 Yaris Join Date: May 2010
AMen Brother! that is why i am waiting on my parts to arrive! even with only 9k on mine... worth it to me to have it factory looking if i ever do have to take it to the stealership!
#38 |
got my parts! did the install! looks factory! it works! many thanks to everyone!
#39 |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
#40 |
![]() Drives: '10 Yaris 3Dr LB, MT Meteorite Join Date: Mar 2010
Congrats! Boy did I miss cc. My 90 mi round trip commute up and down the interstate is soooo much easier!
#41 |
This question is for everyone who installed the cruise control. How did you guys remove those screws that is removed by using the #27 torx? Those screws are so tight it is impossible to loosen them.
On DIY it's not even mentioned how to take the steering wheel apart other than use #27 torx to remove the airbag. I guess no one else had this problem. Parts of my palms are all red b/c of forcing it too much. Am I doing something wrong? |
#42 | |
#43 |
Can you put a picture of the part you are talking about? When I googled it, I couldn't figure out how I can use it together with the #27 torx I got from Sears.
#44 |
#45 |
If you bought a T27 1/4" screwdriver bit, you can make a DIY version of the above, by sticking the bit in a 1/4" socket and wrapping it with tape so it doesn't just fall out.
#46 |
OK thank you very much. Let me try that.
#47 |
i used a socket torx bit... just what i had.. worked great.. as for remvoing the steering wheel... once you have the airbag out of the way.. and MARKED the alignment of the wheel and post... i just wiggled gently but firmly (dont damage the clockspring) and the wheel came loose with only a minute of wiggling.
#48 |
just got back from a trip to florida.. cruise is fantastic.! worked flawlessly
#49 |
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Hye guys... I want to install the CC on my 08 CND Sedan and I am wondering if anyone has a template as to where to punch/cut the hole for the stalk on the cover?
My wife would be very upset with me if I make a bo bo thanks guys! |
#50 |
I purchased my stalk off ebay along with a Scion Tc steering wheel.
This is what the OEM hole looks like: Cruise Stalk Hole.jpg Cruise Stalk Hole2.jpg There was a rubber bushing that mounted over the fins, which fit tightly around the stalk and flexed as the stalk moved: Cruise bushing.jpg I mounted the bushing to my rear cover and then used the center of it as my drill guide (I drilled a 1" round hole, rather than trying to duplicate the square one: Cruise Stalk Bushing2.jpg Before I installed the bushing I scanned it. Here's a PDF of it. Print it without scaling and it will print a perfect one. You can either cut one out of rubber, or just use the paper one as your template: Cruise bushing.pdf |
#51 |
Hmmm....first mistake, it's boo-boo!
![]() http://dictionary.reference.com/browse/boo+boo CTScott is the man...he'll get you all kinds of info.
#52 |
In the garage doing this as we speak! I have a 2009 lb with conv package I hope all the wiring is in place from CTscotts chart he made looks like I will be good to go. let you know in a few!
#53 |
just finished installing the cruise on my 09 liftback stick with conv package no power windows/locks everything works great! thanks to all the guinea pigs and Sparks Toyota for the good price on parts!!
#54 | |
![]() Drives: 07 Yaris Join Date: Jun 2010
I am waiting for the parts and plan to install as soon as possible on my 07 sedan. |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
| How difficult is it to install the aftermarket cruise control kit? | grampi | Performance Modifications | 3 | 07-19-2007 08:06 AM |
