Old 05-23-2010, 10:50 PM   #37
PhillyG
Drives: 2009 Yaris
Originally Posted by YarisGoFar View Post
I installed it on my 2010 3 LB MT today. I decided to go with the factory steering wheel cover rather than drilling my own hole on a car that has less than 3k miles on it.
AMen Brother! that is why i am waiting on my parts to arrive! even with only 9k on mine... worth it to me to have it factory looking if i ever do have to take it to the stealership!
PhillyG is offline   Reply With Quote
Old 05-26-2010, 05:38 PM   #38
PhillyG
Drives: 2009 Yaris
got my parts! did the install! looks factory! it works! many thanks to everyone!
Old 05-26-2010, 06:19 PM   #39
Revsson
Congratulations!
Old 05-27-2010, 08:20 AM   #40
YarisGoFar
Drives: '10 Yaris 3Dr LB, MT Meteorite
Congrats! Boy did I miss cc. My 90 mi round trip commute up and down the interstate is soooo much easier!
YarisGoFar is offline   Reply With Quote
Old 05-30-2010, 04:13 PM   #41
Soner
Send a message via Yahoo to Soner
This question is for everyone who installed the cruise control. How did you guys remove those screws that is removed by using the #27 torx? Those screws are so tight it is impossible to loosen them.
On DIY it's not even mentioned how to take the steering wheel apart other than use #27 torx to remove the airbag. I guess no one else had this problem. Parts of my palms are all red b/c of forcing it too much. Am I doing something wrong?
Soner is offline   Reply With Quote
Old 05-30-2010, 10:26 PM   #42
On my 09 the airbag screws came off easily with a 1/4" drive socket torx bit. I initially tried the torx bit with a screwdriver, but couldn't break them loose. The extra leverage of the 1/4" ratchet was more than enough.
Old 05-30-2010, 10:43 PM   #43
Soner
Can you put a picture of the part you are talking about? When I googled it, I couldn't figure out how I can use it together with the #27 torx I got from Sears.
Old 05-30-2010, 11:44 PM   #44
Old 05-30-2010, 11:47 PM   #45
If you bought a T27 1/4" screwdriver bit, you can make a DIY version of the above, by sticking the bit in a 1/4" socket and wrapping it with tape so it doesn't just fall out.
Old 05-31-2010, 02:27 PM   #46
Soner
OK thank you very much. Let me try that.
Old 06-01-2010, 09:21 AM   #47
PhillyG
Drives: 2009 Yaris
i used a socket torx bit... just what i had.. worked great.. as for remvoing the steering wheel... once you have the airbag out of the way.. and MARKED the alignment of the wheel and post... i just wiggled gently but firmly (dont damage the clockspring) and the wheel came loose with only a minute of wiggling.
Old 06-11-2010, 10:05 AM   #48
PhillyG
Drives: 2009 Yaris
just got back from a trip to florida.. cruise is fantastic.! worked flawlessly
Old 06-18-2010, 03:35 PM   #49
CB900F2
Drives: 08 Sedan
Hye guys... I want to install the CC on my 08 CND Sedan and I am wondering if anyone has a template as to where to punch/cut the hole for the stalk on the cover?
My wife would be very upset with me if I make a bo bo
thanks guys!
Old 06-18-2010, 04:06 PM   #50
I purchased my stalk off ebay along with a Scion Tc steering wheel.
This is what the OEM hole looks like:
There was a rubber bushing that mounted over the fins, which fit tightly around the stalk and flexed as the stalk moved:
I mounted the bushing to my rear cover and then used the center of it as my drill guide (I drilled a 1" round hole, rather than trying to duplicate the square one:
Before I installed the bushing I scanned it. Here's a PDF of it. Print it without scaling and it will print a perfect one. You can either cut one out of rubber, or just use the paper one as your template:
Cruise bushing.pdf
Old 06-18-2010, 11:03 PM   #51
Revsson
Hmmm....first mistake, it's boo-boo!
http://dictionary.reference.com/browse/boo+boo
CTScott is the man...he'll get you all kinds of info.
Old 07-02-2010, 03:22 PM   #52
2009BBPliftback
2009BBPliftback's Avatar
In the garage doing this as we speak! I have a 2009 lb with conv package I hope all the wiring is in place from CTscotts chart he made looks like I will be good to go. let you know in a few!
2009BBPliftback is offline   Reply With Quote
Old 07-02-2010, 03:58 PM   #53
2009BBPliftback
just finished installing the cruise on my 09 liftback stick with conv package no power windows/locks everything works great! thanks to all the guinea pigs and Sparks Toyota for the good price on parts!!
Old 07-05-2010, 11:44 AM   #54
dbielawski
Drives: 07 Yaris
thanks guys!
See http://www.trdsparks.com/install/000...8Yarisinst.pdf
I am waiting for the parts and plan to install as soon as possible on my 07 sedan.
dbielawski is offline   Reply With Quote
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
How difficult is it to install the aftermarket cruise control kit? grampi Performance Modifications 3 07-19-2007 09:06 AM
