Old 07-04-2010, 01:02 AM   #37
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
Originally Posted by Parmas View Post
The CBR600 coils arrived today...
There seems to be an issue, I am not liking the fact that the plug is just touching the cbr coil tip unlike the yaris coil in which it goes into a fixed spring into the coil tip.
Here are some pics....
To scioncrew... can you post some pics of garm coils to understand I have the right coils here.. Thanks
try removing the spark plug caps.. you will have to us spark plugs that have removable caps. here is picture http://www.yarisworld.com/forums/alb...pictureid=2789
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 07-04-2010, 01:25 AM   #38
scioncrew
scioncrew's Avatar
Drives: SCION tC
just so you know not all spark plug caps come off. it will be very obvious if the cap will come off. if you cant see threads on the cap it will not come off.
Old 08-08-2010, 10:47 AM   #39
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I am recently installing a new engine management and I got a doubt about the coils connection terminals.
In the engine managment manual it says that the positive terminal must be common with all coils while the negative terminals must be connected with external ignitors then to ecu. The problem is that the common wire in the coils stock loom is color coded Black and White and I am suspecting that the wiring needs to be adjusted to match the my management.
Scioncrew.. since you have experience with these coils, do you know which of the terminals is negative or positive?
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
Custom Turbokit 1nz Forced Induction Forum 58 10-09-2009 03:01 PM
Moving the Ignition To The Left? MadMax Cosmetic Modifications (Exterior/Interior) 4 10-02-2009 11:57 PM
Ignition locks? Blowtorch DIY / Maintenance / Service 4 05-13-2009 12:26 PM
