Old 01-20-2007, 02:13 PM   #1
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
15" Konig Heliums+tire weight info
Some more yaris related information in case anyone cares...
I just fit my new 15" Konig Helium rims with a set of super cool tires.
Hankook R-s2 W212 205/50ZR15 (treadwear 200).
The rims weight 11.8lbs.
The rim + tire weights 31.68 lbs
If I compare this with the 33lbs OEM alloys I just JUST reduce 1.3lbs (sucks... you might say) but in the other hand I´m going to be running on a much wider and super grippy tire so I´m quite happy with the result.
Some thing else. This size of tire is a little bit to wide for the heliums... so if you have those rims... you should probably go with 195 instead of 205.
CASTREX is offline
15" alloys weight? obylium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-25-2006 12:05 AM
Stock 15" RS 5 Spoke Rim weight? GabL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-03-2006 05:23 PM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
KONIG HELIUM Ultra LIght Weight wheels C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 31 08-03-2006 06:00 AM
