Old 10-28-2020, 02:51 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Are you sure it's the check engine light? It should only be flashing the P/S light or the ABS light. Blinking check engine light usually means massive intake leak and potential damage to the catalytic converter.
Old 10-30-2020, 10:27 AM   #2
Basmii
Drives: 09 yaris hb
Check engine for sure. It's just blinking during the test procedure, not while the car is running.Four blinks, pause, followed by two blinks. I tried to upload a video but I guess the file is too large.
Unfortunately I'm out of time to work on it right now. I have to travel for a few weeks for work. I'll try to sort it when I get back.
Basmii is offline   Reply With Quote
Old 11-09-2020, 09:44 PM   #3
Basmii
Drives: 09 yaris hb
Returned and looked at it with fresh eyes. Replacing a blown 10amp fuse under the dash fixed everything👍 Drove it a good 100 miles today without issue.
Old 11-10-2020, 07:12 PM   #4
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Feels good, doesn't it!
Old 11-11-2020, 12:26 PM   #5
Basmii
Drives: 09 yaris hb
For sure. It's amazing how much smoother an engine the 2zr is. I'm really glad I spent the extra dollars for the MWR flywheel too.
Old 11-14-2020, 06:42 PM   #6
CrankyOldMan
Awesome, glad it was an easy fix!
Old 12-07-2020, 12:43 PM   #7
Basmii
Drives: 09 yaris hb
1 month update:
No issues after getting the early fuse problem sorted. I've driven it about 1800 miles so far and I'm averaging about 33mpg.
My initial goal for this car was to recreate the performance and feel of some of the small lightweight cars I owned in my younger days (specifically the mk1 gti I had in high school) and it is very close.
It is still not"fast" by any measure,but the 2zr revs quick and is very smooth and torquey above 3000rpm.
Some of the good things:
The MWR flywheel is worth every penny. The clutch action is a little more on/off switch in traffic but it's nothing I can't live with.
The actual swap was much easier than I expected.If you disassemble the front end most everything is accessible and the 2zr fits back in easily.
I'm expecting it to be every bit as reliable as the old motor.
The car gives off a cool "sleeper" vibe now.
And the bad stuff:
The new cat/exhaust continues to smell terrible. I was expecting that for the first couple of hundred miles but it hasn't gone away yet.
It is way loud! I ended up welding on an old school Supertrapp end cap to quiet it down but that isn't a permanent solution.
I decided to replace a bunch of other stuff (axles,control arms, brakes) at the same time and ended up spending alot more money than I initially intended.
I'm not entirely sure if the 2zr sits lower in the engine bay, but my oil pan seems very vulnerable. It's easily the lowest point on the car. I have plans to fab up a protective skid plate out of some hdpe cutting board material but that will have to wait till spring. Hopefully I don't run over anything in the interim.
Old 12-08-2020, 02:39 AM   #8
stidnam
Drives: Starlet
Awesome to hear. With regard to the flywheel - do you notice any rev hang? I have a factory flywheel on my 2zr and it's horrible. So much worse than the 1nz and particularly in 1st gear which is quite short in my setup
stidnam is offline   Reply With Quote
Old 12-08-2020, 12:40 PM   #9
Basmii
Drives: 09 yaris hb
That is still there unfortunately. Can't say if the flywheel improves it without driving them back to back.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
THE 2ZRFE engine swap thread - Just the facts brushforhire Performance Modifications 40 12-24-2019 11:08 PM
2zrfe Engine swap - $500 picked up brushforhire Items for Sale by private party 0 03-17-2017 10:21 AM
My 2zrfe swap brushforhire Performance Modifications 131 06-08-2016 09:43 PM
