Old 05-12-2016, 02:28 PM   #1
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
THE 2ZRFE engine swap thread - Just the facts
Here is the basic rundown of what is needed to do this swap:
2ZRFE engine
xD ECM
xD Engine Harness
ECM and Harness should be both from the same trans as the one you want to use, e.i. auto or manual
xD Alternator
xD A/C compressor
xD MAF sensor and intake - see intake section for better details
xD belt
xD exhaust - see exhaust section
Passenger side engine mount - Part number 12305-37091
(The engine side bracket is 12315-37040, but that should be on the used engine you get)
Mini Add-a-fuse - see wiring section
Or if you have ABS, then you can steal the speed signal from that, and then use the power supply that would have been for the speed sensor on the transmission.
Oil, filter, coolant, trans fluid.
That will be your basic needs. Most everything else like hoses, and radiator fill pipe can be modified.
brushforhire is offline   Reply With Quote
The 2zr-fe engine swap guide ArmstrongRacing Performance Modifications 416 08-14-2023 03:14 PM
engine swap yaris9876 DIY / Maintenance / Service 12 12-26-2013 10:27 PM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Engine Swap Nutzoids Performance Modifications 42 10-01-2007 06:20 PM
if i am thinking about an engine swap - from 1.3 to 1.5 - please help ASHRAF Performance Modifications 15 01-03-2007 01:40 PM
