Old 01-02-2010, 12:31 PM   #37
Boost Addicted
Drives: 2008 Yaris 5spd, 2005 GLI 1.8T
just to clarify for those of us with auto transmissions....what you all are doing is just draining and filling the trans pan.
what supmet stated was $250 was probably a fluid exchange (flush and fill)
which takes all the fluid out including that in the torque converter.
Agreed, however I'm looking at Mitchell On Demand as I type, and it says the automatic transmission fluid capacity is 2.6 quarts, or 2.5 liters... Compaired to that of which another member above replaced 4 quarts.
It just struck me when I saw the capacity vs. what someone else put into the car after a drain. Figured I'd mention the spec..
The manual trans is 2.0 quarts or 1.9 liters.
And to get to my actual point here, I'm wondering how you guys like the Royal Purple? I've heard mixed reviews... I must confess, I'm actually a Volkswagen guy (My girlfriend owns the Yaris) and people weren't too impressed with it in the 6 speed GLI's which is what I have. And I want a REALLY good synthetic for the Yaris (5 spd) because I noticed it has no syncro for reverse, and sometimes when you put it in reverse (yes, with the car stopped) it gives a quick sharp grind and kinda lurches the car slightly. Can't be good... And I don't want metal shaivings causing havoc. So what do you think is the best synthetic trans fluid out there? Thanks guys!
/rant lol
Boost Addicted is offline   Reply With Quote
Old 01-02-2010, 07:21 PM   #38
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
I put it in my manual yaris I am not that impressed with it on cold morning I feel a little grind when I put it in 3rd gear until it gets warmed up I have been thinking about trying something else
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 01-02-2010, 07:35 PM   #39
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
I put Redline MT-90 in this last summer and love it. And now that winter temps are here I couldn't be happier with the decision to use it. I never really notice a cold shift difference vs. warmed up like I used to. And reverse engages a lot smoother than it did before the change. Give it a try-two quarts will set you back about $22 most places.
Old 01-02-2010, 07:50 PM   #40
gonzo452001
I think I will
oem style foglights
Scan GaugeII
Old 01-02-2010, 08:11 PM   #41
gonzo452001
shouldn't we use the 75w90 instead of straight 90w
oem style foglights
Scan GaugeII
Old 01-02-2010, 08:26 PM   #42
gonzo452001
Ok the mt90 is 75w90 ordered 2qts from amazon
oem style foglights
Scan GaugeII
Old 01-03-2010, 11:35 PM   #43
Boost Addicted
Awesome, I was thinking of using the Redline in both her Yaris and my Jetta. I've heard good things, and I can pick it up locally for 12 bones without having to pay shipping. I'll post back up after the fluid change and tell you guy how I feel about it.
Old 01-04-2010, 11:59 PM   #44
Hershey
you won't be disappointed . Takes a little time to get the full benefit . Work through all the gears , including reverse .
Old 08-30-2010, 02:54 PM   #45
sleey0
Drives: 2008 Yaris LB
Just replaced my MT tranny oil today at 22k miles and WOW! What a damn difference.
Good to get the old gear oil out of there and some new - I bought the car used at 19k miles and who knows howthe original owner drove it or grinded 'em;) lol
REDLINE 75w90 FTW!!!
sleey0 is offline   Reply With Quote
Old 08-31-2010, 01:20 AM   #46
Hershey
It's amazing . No more grinding , smoother shifts , and no clunk into reverse . Used it in a '08 we had . Better cold shifting too . Enjoy .
Old 08-31-2010, 11:21 PM   #47
sleey0
I know it!
I really didn't think it would make a difference ESPECIALLY since the old oil that drained out was very clear and seemed still good.
I wonder what brand and type of oil Toyo uses as the factory fill for the MT tranny.
Old 09-01-2010, 02:12 AM   #48
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
^^^something that has a lot of assembly lube in it most likely....
Old 09-01-2010, 11:22 AM   #49
sleey0
Yeah, you are prob right. lol
Old 09-01-2010, 11:54 AM   #50
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Is 75w90 the correct weight for 5 speed?
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 09-01-2010, 12:04 PM   #51
Hershey
yes , GL-4 as well . Not GL-5 .
Old 09-01-2010, 03:05 PM   #52
sleey0
Hmmm.
I used red line 75w90 that was GL-5.
Is this going to be an issue? What are the drawbacks to using this oil vs. the MT-90 which is GL-4?
Old 09-01-2010, 10:38 PM   #53
Hershey
is it this one www.redlineoil.com/product.aspx?pid=47&pcid=7 or this one www.redlineoil.com/product.aspx?pid=46&pcid=7 ? If it's the 75w-90 NS GL-5 you should be fine . Says has improved copper corrosion protection for life of syncro . Give them a call at 1-800-624-7958 and ask if it's compatible with the YARIS . They're very helpful .
Old 09-01-2010, 10:47 PM   #54
sleey0
It is the NS 75w90.
I'll call em up. Thanks!
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 01:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
