Old 12-06-2009, 02:45 AM   #1
charleschia1986
charleschia1986's Avatar
Drives: Yaris RUSH HatchBack
thanks CTscott for ya Helpsssss,
here is the link of my Final product.
u may have a look.
http://www.yarisworld.com/forums/showthread.php?t=24210
charleschia1986 is offline   Reply With Quote
Old 12-22-2009, 10:23 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Hi all. Is there a place I can tap into the engine bay for turn signals besides the wires that lead to the signal lamps?
Old 12-22-2009, 11:08 PM   #3
You can tap into the turn signal wires in the under hood fuse panel. On connector B13 (left connector in this picture), the light green and dark green wires in the upper row (next to the two red wires for my fog lights) are the turn signals. Light green is left, dark green is right.
Old 01-21-2010, 01:35 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
One more question, where can I tap in for the parking lights - the lights that go on just before I turn on the headlights?
Old 01-21-2010, 11:32 PM   #5
The White wire next to the blue and orange on the headlight stalk connector. You ground the wire to make the lights come on.
Old 01-22-2010, 01:50 AM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Sorry, should've made my question a bit clearer. I'm looking to see if there is one in the fuse box like the one pictured above.
Old 01-22-2010, 06:22 AM   #7
In the fuse panel, it is pin 3 on Connector B13, which is the green wire next to the two red wires in my picture above. If you don't have fogs installed, the place where the two reds are in my picture will be empty on yours.
Old 09-22-2010, 10:54 AM   #8
sleey0
Drives: 2008 Yaris LB
I just want to take a minute to say a big, fat THANK YOU to ctscott for his help on these boards.
I have used a lot of your info and I believe you deserve at least this much appreciation!
Thanks, brother!
sleey0 is offline   Reply With Quote
Old 10-21-2010, 10:23 PM   #9
nmd55
Drives: Yaris Liftback
it tried tapping the light blue wire at the headlight switch, but now my headlight wont turn off and the lights on my power window switches are on all the time?
did i just do a bad job tapping this? or can i not tap the light blue wire for my power window switches?
thanks,
nick
nmd55 is offline   Reply With Quote
Old 10-21-2010, 10:28 PM   #10
Tried tapping that wire for what purpose?
Old 10-22-2010, 11:27 AM   #11
nmd55
the power window switches i got light up at night when the headlights are on
Old 10-22-2010, 11:44 AM   #12
OK. First off there are two blue wires on the headlight stalk. The "light blue" is the darker of the two. The other color is called "sky blue".
Secondly, you don't want to use a high current circuit, like the headlight switch, to drive interior lighting. You want to use the illumination circuit, which you can access either at the shift lever or at the dimmer rheostat.
At the shift lever, there is a two pin connector with a white and a green wire. Green is +12, white is ground.
At the dimmer rheostat, there is a 10 pin connector. The sky blue wire is +12 and the light green is the headlight switched ground.
Old 10-26-2010, 01:57 PM   #13
nmd55
^^ awesome thanks so much for the info!!!
Old 10-26-2010, 10:26 PM   #14
nmd55
So i tried the sky-blue wire at the dimmer and it works. However its dimming the power window switches in the opposite direction as the dash. So when the dash is fully lit, the power window switches are not lit at all and vice-versa.
I checked the connection with my multi-meter and it is indeed +12V so im not sure whats wrong.
My car is MT so there is no shift lever, is there another headlight source i can tap?
Thanks for the help!
Old 10-26-2010, 10:48 PM   #15
So i tried the sky-blue wire at the dimmer and it works. However its dimming the power window switches in the opposite direction at the dash. So when the dash is fully lit, the power window switches are not lit at all and vice-versa.
That's correct. Is the light wiring on your switch separate from the switch controls, or is it integrated, where it shares the same ground? It sounds like the latter, as the dimmer brings the ground up, rather than the +12 down to do the dimming. If that's the case, using green as your + and chassis ground as your ground should correct the reversed behavior.
Old 10-26-2010, 11:25 PM   #16
nmd55
as it turns out i was tapping the LG wire the whole time thats why it was dimming in the opposite direction. However the SB wire is an ignition switched 12V, so tapping that doesnt work either because the switches are on all the time with the SB wire.
I think i am going to have to find another source to tap.
Old 10-27-2010, 08:23 PM   #17
I just realized that I gave you the wrong wire for the +. Use the brown on the dimmer rheostat, not the blue.
Old 04-23-2011, 07:40 PM   #18
MudBug
Drives: 07 Yaris
I put an aftermarket stereo in my 07 hatch but I couldn't find the dimmer wire.
The stereo has this feature.
This blue light is almost blinding at night.
Is there a dimmer wire in the stereo bundle?
MudBug is offline   Reply With Quote
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
