Old 06-28-2011, 12:38 PM   #55
auxmike
auxmike's Avatar
Originally Posted by ROCKLANDTOYOTA View Post
must be how im looking at it but they do look DIFFERENT....
I'll see if I can post a pic of those two and the metal oem one after I get home.
Old 06-29-2011, 12:18 PM   #56
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
Originally Posted by Bluevitz-rs View Post
Put a jack under the oil pan and undo the passenger side motor mount.
I've done that, but the motor still doesn't drop.
goliath1812 is offline   Reply With Quote
Old 06-29-2011, 12:22 PM   #57
you lowered the jack and the motor didn't move?
Old 06-29-2011, 05:24 PM   #58
goliath1812
nope, didn't move one bit. the jack wasn't even touching the oil pan.
Old 07-02-2011, 04:12 PM   #59
auxmike
auxmike's Avatar
I just put a 4ft prybay to the side of the engine and pryed while sliding out the pump...
I did'nt even have to remove a tire.
Old 08-01-2011, 04:19 PM   #60
sort_o_sane
Yaris GSR LOL
sort_o_sane's Avatar
Drives: 07 Yaris Hatch
Other than the Autozone or Kragen/O'Reilly replacements, is there something a bit better for an aftermarket replacement?
This also makes me want to look into an oil cooling kit for my yari :)
07 Yaris hatchback purchased in Dec '06. April 2015 and 103k miles, brakes finally needed changing, original battery finally died. I love this car.
sort_o_sane is offline   Reply With Quote
Old 08-01-2011, 04:26 PM   #61
auxmike
auxmike's Avatar
I bought the AC Delco one. Madeinthe USA !
Old 08-06-2011, 04:20 PM   #62
sort_o_sane
Yaris GSR LOL
Ok, this is going to sound completely stupid, but how in the hell do i get the mount to separate when I'm trying to drop the motor?, bolts removed and the damn thing won't budge. WTH?
Old 08-06-2011, 04:24 PM   #63
sort_o_sane
Yaris GSR LOL
let me also add the i beat the hell out of a pipe i had using it as a pry bar and was tempted to climb onto the engine and jump on it...
Old 08-06-2011, 08:09 PM   #64
sort_o_sane
Yaris GSR LOL
never mind, i'm a dumbass and see the tip of the bolt that held the nut i need to remove...
Old 08-07-2011, 09:28 AM   #65
bronsin
bronsin's Avatar
SWEET!
Old 08-07-2011, 09:56 AM   #66
auxmike
auxmike's Avatar
I don't recommend doing this any more, I put a nice dent in my a/c line!
Old 08-07-2011, 11:03 AM   #67
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
you have to take out a bolt anyways might as well take off the ac compressor instead of dropping the engine then the pump will clear i watched the way toyota did it..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 08-07-2011, 11:22 AM   #68
auxmike
auxmike's Avatar
I wouldn't do that, especially without a lift. When I used the prybar I didn't
Mess with any bolts..
Old 08-07-2011, 12:46 PM   #69
bronsin
bronsin's Avatar
Well now we know better.
Where and what did you pry against? Besides the AC line I mean?
Was it a case of PRY....quick wp out...PRY...quick wp in?
I THINK I can control myself not to rush and think about what I am doing and so avoid ruining my car.
Is it possible to get the old wp off then cut a piece off it with a dremel so as to be able to remove it?
Perhaps there are extrainious parts on the new one that could be ground off to get it in there?
Im like the people who cut jeeps into four pieces with a cutting torch to fly them in C47s over the Hump in WW2 then welded them back together again once they got there.
Whatever works think outside the box.
Old 08-07-2011, 04:50 PM   #70
auxmike
auxmike's Avatar
Bronsin, I pried on the center of the crank pulley, NOT the timing chain cover. You have to pull REAL hard whist sliding out the pumps. Those AC lines are thin aluminum tubing,watch out!
Old 08-07-2011, 09:31 PM   #71
c-dub
Drives: 2008 yaris
did my girls today. didn't drop the motor, but needed to pry it back about 1/2" to get the pump out and in. used a 1/2" breaker bar between the motor mount and the head. didn't need any force, the blocked moved easy.
c-dub is offline   Reply With Quote
Old 01-10-2013, 08:43 PM   #72
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
When you said you dropped it 2 inches. Did you undo the the motor mount bolts?
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY Requests. TinyGiant DIY / Maintenance / Service 13 10-29-2008 10:39 AM
