Old 01-23-2010, 03:03 PM   #55
Originally Posted by IsLNdbOi View Post
There used to be some threads here on YW w/ pictures on removing the steering wheel, the stock stalk and then replacing the stalk w/ a new one. Can't find those threads anymore.
Anyone have links to or have the pics. from those threads?
Take a look through the cruise control threads. I believe in one of them that there are some good pics of removing the steering wheel.
Old 01-24-2010, 12:57 AM   #56
1NZYaris1
1NZYaris1's Avatar
Here you go here is the toyota PDF
for Steering wheel fitting /Removing
Old 01-24-2010, 04:06 AM   #57
IsLNdbOi
IsLNdbOi's Avatar
Thanks guys. The part of the process I'm actually looking for is removal of the original combination switch and installation of the new one w/ the fog light control.
Old 01-24-2010, 08:00 AM   #58
That's the easy part. Once the wheel is off, there are just two plastic tabs that hold the switch. You release those and pop the connector.
Old 01-27-2010, 10:48 AM   #59
IsLNdbOi
IsLNdbOi's Avatar
Got the fog light kit yesterday and I'm not happy with it. On my '07 LB, each fog light mounting hole / spot had two slits where the tabs on each fog light would slide into while the other side would be screwed in.
So, the fog lights for the '07 would have two tabs on each side. On my '09 5-door LB, each fog light mounting hole / spot has one slit where a tab on each fog light should go. The fog lights that came with this kit has two tabs on each side just like the ones for the '07 / '08 LB. For them to fit properly, they should have only one tab on each side. The tab on one side would insert into the slit on the mounting hole and the tab on the opposite side would be screwed into the screw hole on the mounting hole. So, once I installed these fog lights there was a noticeable gap b/w the lights and the bumper. Also, the top edge of the fog bezels pop out a little bit so there's a slight gap b/w the top edge of the bezels and the bumper. I already checked and all the tabs are pushed all the way in, securing the bezels. I don't recommend this kit.
Old 01-27-2010, 11:40 AM   #60
I believe the gap is common to all, not just the 2009 and up.
Old 01-27-2010, 06:01 PM   #61
spookz
JDM yO!
Drives: '09 3dr. 5-spd
The tiny gap is probably so that the heat from the foglamp glass doesn't melt the bezel plastic..
As for the tiny gap on the top edge of the bezel and the bumper, that's normal. I have genuine '09 bezels and they too leave a tiny gap.
Old 01-30-2010, 02:21 PM   #62
IsLNdbOi
IsLNdbOi's Avatar
I don't remember there being gaps like this on my '07 LB. Here are some quick pics. I took:
Old 08-20-2010, 11:50 PM   #63
Revsson
I believe that you can use either the 06-08 (84140-52150) or 09 (84140-52151) versions. TRDsparks sells the 06-08 one for $77. The difference may just be in labeling like the wiper stalk I put on mine. I bought the older version of the Prius wiper stalk and it has text on it, whereas the newer version just has the symbols.
The other place to try is the junkyard that I bought my wiper stalk from (for $50 vs ~$100). http://autoworksinc.com/
Hey CTScott -
Sorry to dredge up an older post, but when you ordered from this junkyard,
did you specify the part number or just the Prius wiper stalk with fog switch?
I don't know if I have the guts to take off the steering wheel to do this,
but that junkyard isn't too far from me, and I have a buddy that lives in the
Madison,WI area. I ordered the fog light kit from Garm, and might just put
the switch that comes in the kit for now.
Old 08-21-2010, 07:27 AM   #64
Originally Posted by Revsson View Post
Hey CTScott -
He had the part number listed, so I checked that out. The Prius wiper stalk works on the Yaris, but the headlight stalk does not, as it has different connectors.
Old 09-27-2010, 12:04 PM   #65
mari
Drives: 2010 sedan
STALK: 84140-52151
RELAY: 90080-87026
SHROUD LH: 81482-52260
SHROUD RH: 81481-52330
I want foglights on my 2010 Sedan, and want to confirm these part numbers are also valid for my car.
Oh, and is there an OEM toyota part number for the foglight wiring harness? I assume that with the new foglight stalk, there is no need for an interior wiring harness.
mari is offline   Reply With Quote
Old 09-27-2010, 04:50 PM   #66
1NZYaris1
1NZYaris1's Avatar
Ifyou get the latest kit from Micro Image (a sponsor of this site )
everything is in the kit apart from the OEM Stalk
which is not required , and the whole kit is nplug and play
Old 09-29-2010, 01:00 PM   #67
mari
Drives: 2010 sedan
thanks... kit price is excellent for the wires and covers, but I like the oem stalk (its only $90 online!) and my own lights (visionx solstice LEDs).
Old 10-01-2010, 04:21 PM   #68
SimTronik
Machinist
Drives: Yaris sedan 2010
Just installed my fog light kit and i just noticed gaps like that. Do i need to order the original toyota bezel? Very disapointed. Help!
SimTronik is offline   Reply With Quote
Old 10-01-2010, 07:03 PM   #69
My genuine Toyota ones fit properly around the outside, but have the same gap around the lens (which may be intentional to avoid melting the plastic).
Old 10-01-2010, 08:38 PM   #70
SimTronik
Machinist
Where can i get some genuine ones. are they expensive? Only the bezel.
Old 10-01-2010, 08:40 PM   #71
Read above in the thread for the part numbers. They are about $26 each from your local dealer.
Old 10-04-2010, 12:30 AM   #72
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
I got the MI kit for my '09 and had them professionally installed. There is the slight gap right above the fog light bezel on each light.
chrisj is offline   Reply With Quote
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
