Old 05-10-2009, 08:25 PM   #1
Originally Posted by Liu997 View Post
How do I do that. It seems like I can't take out the board
You have to snip the black blob of plastic to lift the board. I believe that the Switch LED is cooked from when the jumper was going to the wrong side of the resistor. That would have put 12 volts directly through the LED, which would kill it.
Old 05-10-2009, 08:56 PM   #2
Liu997
Drives: 2008 Red Yaris LB
ugh,..... whatever I give up anyway when I press it, the foglight on the Dash cluster turns on. Wait if you send 12 volts directly to an LED it frys it?
Damn I fried 20 dollars worth of lights
Liu997 is offline   Reply With Quote
Old 05-10-2009, 09:17 PM   #3
If the LED doesn't have a current limiting resistor it will light brightly once. Sometimes they'll even split or pop.
Old 05-10-2009, 09:56 PM   #4
Liu997
Yea that's what happened to my led spot lights, I though it was 12v hardware but it lit once and I though the connection was bad... then used another one and that too fried ughh bad day.
And thanks for all the foglight help anyway
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
