Old 06-08-2009, 06:23 PM   #55
we can slap in a small turbo and run it without major problems with the 1NZFE?
No one said that. There is a risk involved with any major engine modification, including this. What I said is that at least two of us have run turbos and not blown our motors. That is all the data there is -- so choose CAREFULLY before you jump in.
Old 06-08-2009, 06:55 PM   #56
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Can someone make a list of PSI vs Gain or am i talking through my butt?
yeah, through your butt
Just kidding
Is not that simple. It depends on the turbo you use and your set up. So there is no way to say x amount of HP per psi.
You could said though that for any given set up the car puts out xamount of HP for psi. That would be true within a psi range.
IE:
If Garm's old set up made 180hp at 8psi and lets say the base power was 100hp, then you can said his turbo made 10hp per psi. You can also assume that the same set up at 10psi would put out 200hp.
As the PSI goes up and you start going out of the effeciency area or the turbo, the numbers will change (decrease)...
Old 06-08-2009, 06:59 PM   #57
CASTREX
CASTREX's Avatar
Yeah after reading more on here (special thanks to Morgan for actually doing it), I probably would too. May still get around to it.
One of the advantages of standalone management is that you can switch between multiple MAPS...
So you can have th everyday map for regular gas, then a Meth map and finally the all out race gas map.
The Meth map comes pretty handy when you want to have some fun and don't have some VP handy... or if you don't want to pay the race gas price.
240-250whp for every day driving on regular gas
260-270whp on meth
300+whp on race gas
Old 06-08-2009, 10:12 PM   #58
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
and the fact that it makes some of the best hp/lb of ANY engine in any car in the world.
*thud*
Now I've heard it all.
The Spectacle is offline   Reply With Quote
Old 06-08-2009, 10:34 PM   #59
Tamago
Tamago's Avatar
Drives: UZJ100
the next person that uses the term "slap on" in the same sentence as "turbo" needs a permaban.
Old 06-08-2009, 11:23 PM   #60
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
spectacle needs a permaban..........we already have enough bs on the forum as is.
Old 06-09-2009, 01:29 AM   #61
but now seriously is the 1NZFE able to take a turbo without modifications without destroying it?
No one can answer that question with any certainty. I'm not sure how many different ways I can say that. I can only point at the real world data we have, me and Tamago who ran turbos on the 1.5L motor with no damage. Loss in longevity? Again, can't answer that either.
Maybe in 3-5 years, when a lot more people have tried and either succeeded or failed, the question can be answered with some data to back it up.
Old 06-09-2009, 01:31 PM   #62
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
Originally Posted by The Spectacle View Post
*thud*
Has anyone ever told you that you know nothing about cars? or is that a first too!
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 06-09-2009, 05:37 PM   #63
The Spectacle
Drives: 08 BSP LB
Its a first.
Old 06-09-2009, 05:49 PM   #64
mikenacarato
SIPNDEW
Drives: 15 STI
Its a first.
now like a 2nd or 3rd...
Old 06-09-2009, 05:56 PM   #65
Tamago
Tamago's Avatar
Drives: UZJ100
bench racing = real-life, knuckle-skinning experience, didn't y'all know? that's why we can "slap on" turbos and coilovers....
Old 06-09-2009, 10:09 PM   #66
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
lol @ the bashing on spectacle.
Old 06-09-2009, 11:07 PM   #67
Tamago
Tamago's Avatar
Drives: UZJ100
you feel left out?
Old 06-10-2009, 02:05 AM   #68
CDavis7M
Drives: 1990 Supra Turbo
I don't have any experience with a Yaris, let alone a turbo one. But, I do have a turbo supra.
Here are some of the basics that I know about Turbo cars. Please let me know if I am wrong though.
-A car with a Turbo stock will have an ECU that is set to retard timing at higher rpm / higher boost.
-Turbo cars have much lower engine compression and are better able to handle boost.
-NA cars try to achieve a Air/Fuel Ratio of about 14.7, probably richer than that at about 13-14 or less when at full throttle.
-A Turbo cars ECU is set to run at 11-12 AFR at full throttle. Running richer allows the gas to cool the piston and reduces the risk of detonation.
-Turbo cars usually have some or all of the rotating assembly forged.
So, basically, running a turbo without any modifications on an economy engine, you will detonate with AFRs around 14, even at 7psi. I hope someone before me set you guys straight but this thread looks like Honda Tech. It's just horrible.
CDavis7M is offline   Reply With Quote
Old 06-10-2009, 02:15 AM   #69
Tamago
Tamago's Avatar
Drives: UZJ100
guessing you missed the part where we suggested bigger injectors to help with the "stock" AFR's ?
when the car goes into open loop mode, larger injectors will provide more than enough fuel to keep boost mode cool
Old 06-10-2009, 10:39 AM   #70
I hope someone before me set you guys straight...It's just horrible.
You've clearly missed quite a bit of this discussion, you haven't played with a 1.5L Toyota motor, and your tone of disrespect (post count: 4) for some pretty knowledgable tuners is the horrible part. /rant off
Old 06-10-2009, 02:56 PM   #71
Split
Drives: 2008 Yaris Sedan
someone put one of these turbos on the yaris:
http://www.compturbo.com/products/in...&product=CT340
TO4E T3/T4 Hybrid turbocharger with a 40mm Comp wheel stage 1 turbine wheel .36 Non-Port T3 turbine housing.
The Triple Ball Bearing version is only $1600. Instant 250hp at low rpm would be nice!
Split is offline   Reply With Quote
Old 06-10-2009, 03:00 PM   #72
mikenacarato
SIPNDEW
Drives: 15 STI
i think people forget that all cars are NOT the same.....a yaris motor is quite different than a turbo supra motor..correct me if im wrong though please.
Small cars stacked up at dealerships. freeridelectric New YARIS Purchase Forum 11 04-24-2009 08:23 AM
Small car's name? yaris-me Off-topic / Other Cars / Everything else Discussions 13 03-29-2009 02:43 PM
Small science fiction story I wrote which includes the Yaris. :) john21031 Off-topic / Other Cars / Everything else Discussions 3 11-21-2008 12:57 PM
How Small Would You Go? Nigal General Yaris / Vitz Discussion 26 06-15-2007 08:44 PM
small 4ch amp. 4x100rms ben dover In Car Entertainment + Electronics (audio / video / alarm) 2 04-08-2007 04:17 PM
