Old 07-08-2007, 01:30 AM   #1
BrazdonW
What kind of car is that?
Drives: Yaris 3d liftback
Thumbs down anyone know the benifits of lightweight wheels?
i understand lighter wheels should be less work for the car and maybe pep the car up some but im wondering by how much? is there some kind of formula i can use to determine it?
Old 07-08-2007, 01:49 AM   #2
BrazdonW
sorry wrong thread
but i still need answers lol
Old 07-08-2007, 02:14 AM   #3
I'm not sure of an actual formula, but search google for the following terms:
Unsprung weight
rotational inertia
and you'll learn a lot
Old 07-08-2007, 08:26 AM   #4
BrazdonW
good plan :)
Old 07-10-2007, 08:47 AM   #5
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Just less total weight. I seen something once talking about gas mileage for every like 100lbs you loose off your car you gain like 3% more fuel effiency. I have seen people toss their spare tire and everything.
Old 07-10-2007, 12:57 PM   #6
CaysE
That Focus Guy
CaysE's Avatar
Drives: 2004 Focus RSVT
Less rotational weight has a larger effect than less total weight. It's the same thing as having a lightweight flywheel: your engine can rev faster because there's less resistance to it spinning. It doesn't increase horsepower or torque (except to the ground), but it does increase acceleration.
CaysE is offline   Reply With Quote
Old 07-10-2007, 01:41 PM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
I find it hard to believe that reducing rotational weight by just a few pounds per corner will make any significant difference in fuel savings or acceleration.
Old 07-10-2007, 08:03 PM   #8
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Unsprung weight is bad for handling. Unsprung rotational weight is worse. The bit less wheel weight makes your car accelerate and brake faster.
You see some racing cars run bigger wheels simply because they need to fit bigger brakes inside the wheels, for lower stiffer sidewalls, and because they have power to spare to turn monster 18 inch wheels.
Which is why I can't see the point of anything bigger than 16s on a Yaris. The car isn't fast as stock, you're making it slower by throwing wagon wheels on it.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 07-10-2007, 10:36 PM   #9
keesue
Chillin' out by the Bay
keesue's Avatar
You see some racing cars run bigger wheels simply because they need to fit bigger brakes inside the wheels, for lower stiffer sidewalls, and because they power to spare to turn monster 18 inch wheels.
Well said.
Gettin' all the way down.
Meteorite '07 HB STILL completely stock; but....
checkin' out da other ones to see what's what.
keesue is offline   Reply With Quote
Old 07-10-2007, 01:47 PM   #10
CaysE
That Focus Guy
CaysE's Avatar
Welcome to physics 101. o.O
And "significant" is subjective. On a car that makes less than 100hp, dropping 5 pounds off of each wheel is going to make difference enough that you'll notice it.
Old 07-10-2007, 02:20 PM   #11
kimona
kimona's Avatar
Actually "significance" is not subjective; it is a mathematical calculation with a foundation in simple statistical analysis.
Certainly less rotational weight makes some difference... "Welcome to physiscs 101"... but the question is whether a few pounds per corner will make any significant difference in gas consumption and acceleration.
Old 07-10-2007, 02:31 PM   #12
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
the difference in consumption will likely come from over all weight loss any loss woul be a benefit to a degree but the unsprung weight is the wheels and tires
I think I'm just agreeing with you here
SPONSORED BY
Old 07-10-2007, 03:12 PM   #13
kurokoma-kun
Drives: 2007 Yaris HB
My question would be, is there any disadvantage to lightweight wheels?
I bought mine based on design, but was pleased to find out they weigh just 11.8 lbs apiece! Then I read something that said wheels can be too light...something about reduced traction...which just confused the hell out of me...
my yaris, kurokoma-kun
Old 07-10-2007, 03:20 PM   #14
brickhardmeat
Lonesome Cowboy
I doubt anything we could get are hands on in a 14 inch or more wheel size would be too light with a tire on it. I've never heard it put that way. I have heard about braking problems with oversized wheels. I think the lighter the better but then strength maybe an issue
SPONSORED BY
Old 07-10-2007, 03:47 PM   #15
CaysE
That Focus Guy
CaysE's Avatar
If you drive the car to work a few times a week and have plenty of money for gas, it is far less significant than someone else who is on a road or auto-x course looking to shave off tenths of a second. This is called subjective. English 101?
I'm just busting your balls, don't take it personally; I don't even know you. I think we're on the same page... you're talking about daily driving and I'm talking about racing. You're not going to notice like a 20% improvement in gas mileage or something crazy, but you'll definitely notice better course times.
Old 07-10-2007, 01:59 PM   #16
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
True story.
Turbo&Auto is offline   Reply With Quote
Old 07-10-2007, 02:10 PM   #17
brickhardmeat
Lonesome Cowboy
unsprung weight matters, the less the better
SPONSORED BY
Old 07-10-2007, 02:17 PM   #18
CaysE
That Focus Guy
CaysE's Avatar
Lower unsprung weight is a result of lightweight wheels, as well, and will improve suspension response.
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
Do bigger wheels and tires improve performance Driver Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 10-14-2006 06:01 PM
Enkei RZ5 wheels on Liftback kennywhy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-23-2006 04:22 AM
