#73 |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
Seriously. I was just thinking about this thread. Babies ruin everything!
#74 |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
2004 Toyota Echo with the 1.5L 1NZ-FE and have just under 90,000 miles on them for $87 - is the mileage too high or should that matter for my CAM swap?
#75 | |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
#76 |
#77 |
![]() Drives: 2009 3rd Polar white Join Date: Apr 2011
I have hard of people doing the Prius piston swap before, but they always seem to disappear. I think the reason is that they are cast pistons with too much compression. At 13:1 compression, you would have to run full race gas, which at $9.00 a gallon would be extremely expensive. Also, cast pistons can't withstand that kind of compression for very long. You would need to go with forged pistons. You should also swap out the crapy stock Yaris rods while you are at it. They are known to be weak and the turbo guys have shown over and over again that they can't with stand much of a power increase.
#78 | |
#79 |
![]() Drives: 2012 Yaris SE 5-speed Join Date: Mar 2012
The Prius Atkinson Cycle cams have the effect of lowering cylinder pressure due to holding the intake open longer and blowing intake charge back into the intake manifold. Thus the higher compression 13:1 pistons do not result in necessarily higher cylinder pressures that the lower compression ration Yaris pistons.
#80 | |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
Basically the dynamic CR of the 1nz-fxe probably isn't that much different than the DCR of the 1nz-fe... 13:1 is a very high static CR to start off on a regular fuel injected motor, ESPECIALLY with the stock cams. It's just too bad nobody's come back and said what's happened.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
#81 |
Only Happy When it Rains
I remember reading the highest the Prius ratio ever gets is 11.1. The atkinson cycle keeps both the intake and exhaust valves open for long periods of time.
Colin Chapman disciple |
#82 | |
When I do the Cam and Cam gear swap I would basically have the 1NZ-FE head but still the Prius bottom end. Where someone else with the 1NZ-FE would have to tear into the block and switch the pistons but hopefully leaving the stock 1NZ-FE crank. The 1NZ-FXE Does have different pistons and crankshaft but same rods. Would be really interesting to see if there would be a difference it would make between the 1NZ-FXE and 1NZ-FE crank obviously other than part #s being different.. |
#83 |
WTB: 1NZ-FE cylinder head or I/E cams and cam gear
I'm still on the hunt for a set of 1NZ-FE cams and cam gear. I'd rather not go and pick up a full long block for $400-$600 - but i may have to. I'd rather just snatch a full 1NZ-FE head or even just the cams and gear.
I really want to try this out. |
#84 | |
The dynamic CR is apparently 11:1 if you use FXE pistons. I was under the impression that the FE & FXE cranks were the same... or at least the stroke is. Maybe the FXE crank is stronger somehow? To answer your question, it depends. A quick googling seems to say that there's diminishing returns, especially since you're not improving the breathing of the motor and filling the combustion chamber with more air/fuel. One calculator said 6.5% and that's more or less what I read on another site as well... which I think is a bit low, but could be bang on. In any case, a 6.5% increase is 7hp. If possible, I'd go with an overbore Prius piston to help increase displacement at the same time as increasing the CR... that'll help engine breathing, and it'll increase the quench area inside the combustion chamber which should help stop some detonation too.
#85 | ||
1NZ-FE: 13401-21020 1NZ-FXE: 13401-21040 Difference No idea... Quote:
#86 |
crank is the same. They'd use a different part number if it was different. It is really all about pistons and the timing. the atkinson cycle doesn't give a damn about low end tourque, unlike the normal otto cycle.
#87 |
Read much of the other posts??
#88 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
^ burn
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#89 |
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
^LMAO
#90 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Here's a fascinating animation of how Atkinson cycle engines work: http://www.youtube.com/watch?v=hEfOxKmCstg Skip to 2:20 second mark to get past the bullshit. |
| 2010 Prius | tuckevalastin | Off-topic / Other Cars / Everything else Discussions | 60 | 01-13-2009 12:24 PM |
| Stupid prius | KSIbucky | Tracking, Racing, Auto-X Forum | 11 | 09-25-2007 11:07 PM |
| ZPIracing Turbo Pistons | ZPIracing | Forced Induction Forum | 22 | 05-29-2007 03:39 PM |
| And You Thought the Prius Was Expensive! | redyaris | Off-topic / Other Cars / Everything else Discussions | 5 | 05-18-2007 05:11 PM |
| Toyot Prius | YamilR | Photo-Video-Media Gallery | 4 | 02-14-2007 06:54 PM |
