Old 01-11-2013, 01:09 PM   #73
sort_o_sane
Yaris GSR LOL
sort_o_sane's Avatar
Drives: 07 Yaris Hatch
yes, just on the passenger side. both or at least there were 2 on mne
07 Yaris hatchback purchased in Dec '06. April 2015 and 103k miles, brakes finally needed changing, original battery finally died. I love this car.
sort_o_sane is offline   Reply With Quote
Old 02-18-2013, 12:14 AM   #74
baseballfan416
Drives: 2017 L 3-door
Did you drain coolant or merely have to fill it back to acceptable range given the amount that leaked from the pump?
baseballfan416 is offline   Reply With Quote
Old 02-21-2013, 01:55 AM   #75
baseballfan416
ttt
Old 03-16-2013, 02:15 PM   #76
cbmago
Drives: yaris
Originally Posted by sort_o_sane View Post
Ok, this is going to sound completely stupid, but how in the hell do i get the mount to separate when I'm trying to drop the motor?, bolts removed and the damn thing won't budge. WTH?
on yaris from 2003, i´m trying to follow this DIY... already remove the two bolts from passenger side mout but no drop. What is missing? thanks
cbmago is offline   Reply With Quote
Old 03-16-2013, 02:49 PM   #77
hw6515
Drives: 08 Yaris AT, 350Z GT MT
I though of adding that to the guide at some point, there is a 3rd bolt from the bottom.
I can tell you the size or make a pic if you need it.
hw6515 is offline   Reply With Quote
Old 03-16-2013, 02:54 PM   #78
cbmago
Drives: yaris
ok! ia go to the car and see it now ( and try to continue the replacement :)
Thanks
Old 03-16-2013, 02:56 PM   #79
hw6515
refresh the page, pic is in my previous post.
support the engine before loosing the final bolt.
If you have any other question, let me know.
Old 03-16-2013, 03:01 PM   #80
cbmago
Drives: yaris
Got it! :)) spent almost all afternoon trying to find why!!!!!!!!
Thank you very much for your help :)
Regards
Old 07-10-2014, 09:33 AM   #81
murfy
Yaris Verso 2000, I loosened the 2 top bolts on the engine mount and the nut on the underside of the mount a couple of turns, I then got a nail bar and some wood and levered the engine, this shifted the engine enough so the pump came out easily.
Thanks for the original guide
murfy is offline   Reply With Quote
Old 07-10-2014, 09:54 AM   #82
bronsin
bronsin's Avatar
Whats a nail bar?
Old 07-13-2014, 10:05 AM   #83
ws6toto
Drives: 07 yaris
I just did my waterpump on my 2007 yaris two weeks ago i didnt had to loosen the two top bolts from passenger side mount,I had enough room to take out and install the waterpump,I just took the waterpump pulley off.
ws6toto is offline   Reply With Quote
Old 09-29-2014, 05:29 PM   #84
Originally Posted by Veganman View Post
I just changed out the water pump on our 2007 Yaris at 190,000 miles. It never leaked a drop but began making a disturbing noise that was very difficult to track down. After referring to many posts on Yarisworld, I felt confident the noise was in the pump even though it felt fine when the belt was removed and the pump was turned by hand. The only additional comments I would make are as follows: I never had to lower the front of the engine by 2"; in fact, I didn't lower it at all. The pump can be removed and the new one installed by carefully turning and twisting it a bit.
I bought a replacement pump and a metal gasket from Auto Zone and everything worked out perfectly. Total time to replace the pump and get the car running again was 2 1/2 hours.
Good point. I found that unbolting the AC tubing mount, that sits by the pulley, also helps with being able to remove it without lowering or raising the engine.
Old 10-06-2014, 10:09 PM   #85
En4sir
En4sir's Avatar
Drives: '09 Yaris 3dr HB 5sp
Did you buy the Duralast water pump (AWP-9187)? How many miles have you driven since replacing the pump with an aftermarket? Any issues or recommendations?
"Never argue with an idiot. They drag you down to their level, then beat you with experience."
En4sir is offline   Reply With Quote
Old 03-05-2016, 01:15 AM   #86
"G"
Drives: 2007 Yaris Hatch
Mine has 200k and is not leaking yet. But I did flush my coolant at the recommended service intervals and only used toyota pink fluid.
"G" is offline   Reply With Quote
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY Requests. TinyGiant DIY / Maintenance / Service 13 10-29-2008 10:39 AM
