Old 06-27-2012, 08:01 AM   #1
Hussain-Vtec
Hussain-Vtec's Avatar
Drives: ECHO NCP-12/2NZ-FE
Some Search TRANSAXLE ASSY part no..
TRANSAXLE ASSY, MANUAL ( 30300‑1A260 ) C160-12C LSD
1999 TOYOTA LEVIN (AE111-ACFVF) LVN BZR JPN CP 4AGE MTM 6F
Link
http://autoconnectioninc.net/DaCart/...oducts_id=8093
30300-1A260 TRANSAXLE ASSY, MANUAL 01.04.1997-01.08.2000 AE111..BZR ***6-speed***
30300-1A250 TRANSAXLE ASSY, MANUAL 01.04.1997-01.08.2000 AE111..BZG..6F
41301-12041 CASE, FRONT DIFFERENTIAL 01.05.1995-01.08.2000 AE11#..MTM..(BZG,FZ,XZ)
41301-12190 CASE, FRONT DIFFERENTIAL 01.05.1995-01.08.2000 AE111..MTM..(BZR,BZV) ***LSD? ***
Hussain-Vtec is offline   Reply With Quote
Old 01-25-2014, 07:10 AM   #2
EchoLaQua
EchoLaQua's Avatar
Drives: Toyota Echo Turbo
Dude I've been searching for ages trying to find the C160.
I have come accross a few but they dont look the same as yours
They all say in their ad that they're a C160 but Im not convinced. They look completely different. Could it be the year model? What did yours come out of?
I've attached some images, yours is the one with 3 question marks, the other is one I have foung elsewhere (1 question mark).
Also here is a link to another one on ebay (http://www.ebay.ie/itm/JDM-Toyota-Co...#ht_783wt_1114). I get that its sold but it looks different too?
EchoLaQua is offline   Reply With Quote
Old 01-25-2014, 08:52 AM   #3
Mine is pictured re-assembled with the 5 spd bell housing on it. You did read the thread right?
Old 01-25-2014, 09:39 AM   #4
RJay
Drives: 2002 Toyota Yaris T-sport
Hmm, all of those gears minus the 1st are longer than in my 5 spd, but that 6th does look nice.....
198X BMW E30 modified race car
1975 Ibanez "Les Paul custom"
RJay is offline   Reply With Quote
Old 01-25-2014, 10:11 AM   #5
Every gear is shorter than the 5 spd with the 4.5 final. I regularly use 2nd to start because 1st is so short.
Old 01-25-2014, 10:36 AM   #6
RJay
So, if you've got an open gearbox anyway when replacing it, can't you drop out a gear or get a different one? My first gear is rather nice, goes to about 30 mp/h.
Shift to 5th at 100-105 mp/h though, so not too bad :)
Old 01-25-2014, 10:55 AM   #7
The gears as far as I know are not interchangeable. 5th gear in the 6 spd only goes about 145-150km/h and has the engine turning around 4100 rpm at 100km/h. Not ideal for every day use.
Old 01-25-2014, 01:20 PM   #8
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
In theory the gears from 3rd to 5th could be interchanged if the shafts have the right splines, but 6th gear would require some investigation. If you need to drop the freeway RPMs in 5th gear, get a 5th gear set from an '03 Matrix C59 gearbox. Most of the 5-speed gearboxes have a 0.815:1 5th gear, but both the 5- and 6-speed gearboxes from that gen matrix have a 0.725:1 5th/6th gear respectively.
At this point, the only way to know for sure with the other gears is to get the parts and see if they fit.
Old 01-25-2014, 11:14 AM   #9
RJay
No, that's a bit obnoxios indeed. I do 4000 rpm at 117 km/h GPS (so about 125-130ish clock) and 3500 rpm at 103/104 gps in 5th.
Never got to the v-max yet, I call game over after I've hit 63k in 3, 68k in 4 and then shift to 5th.
'cause honestly, all that does is increase the bill you get from the state. ;)
Old 06-02-2016, 09:14 AM   #10
Minor update
After going Boosted, I changed the gear lube to Royal Purple 75w-90 and it fix any problems I had with 4th gear.
I now wish I had an option to swap in a lower ratio Final Drive as I have so much torque now on the highway to save even more fuel. Average is 6.0-6.3L/100km
Old 06-02-2016, 10:35 AM   #11
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
There is a lower final drive available for the c60 but good luck finding one, it was used on european mr2 spyders. I believe the final drive is 4.3.
2014 BSpec Divisional Champion
Old 06-02-2016, 12:30 PM   #12
I've seen the options but nothing available in North America. Monkey Wrench Racing sells them and actually I can go to a 3.9:1 but the cost for me with exchange rate is way more than my whole transmission.
Old 06-03-2016, 02:09 PM   #13
I know a guy that has a link to euro c60's with high FD and LSD...$1000-ish, iirc
Old 06-03-2016, 03:19 PM   #14
Yeah my C160 no LSD was $600 CND
The 4.5FD was perfect for NA application but with the turbo it just revs unnecessarily high.
Old 06-06-2016, 04:07 PM   #15
Sorry, I meant lower FD... I want to say 3.9
Old 06-06-2016, 06:55 PM   #16
Old 06-28-2016, 08:20 AM   #17
Is there a good/easy way to swap out 5th in an echo for something that'd net lower highway rpms? Will the 0.729 from a c60 fit in a C150 from an echo?
Old 06-28-2016, 09:06 AM   #18
I'm not sure on that one. The Echo already has the lowest highway RPM I'm pretty sure with its .815 5th and 3.5FD
You'd have to see if there's any 5 spd gearboxes with the lower 5th. I think the spot where 6th goes is a different Ø
6 speed, conversion, gearbox, transmission
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
