Old 09-27-2007, 02:02 PM   #73
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Originally Posted by dsc_pat View Post
do you have mechanic experience ?
I'm not a professional mechanic, but I've done suspension installs on several cars before including two xBs, which is why I figured I wouldn't have a problem with this car.
I can't stress enough that the install is NOT HARD. What was tricky was finding out what OEM parts needed to be used, which is NOT listed in any literature. However, now you all know!
Originally Posted by CKMotorsport
after you tried this kit can you give me the review. because after what's happen, I never trust any taiwanese product.
Well, I wouldn't judge an entire nation's products based on one bad experience.
Let me get some seat time in this car, and I'll let you know if it's too stiff. I want to crank the dampning up to see how stiff this thing really can be.
Old 09-27-2007, 02:06 PM   #74
kapo
Argentina Presente!
Drives: 07 White LB
Thirty-Nine.. maybe you know..
1. to lower or raise the car.. we need to turn the cylinder? or the top spring perch (as your drawing)? can you measure from the bottom until you touch the threaded cylinder please? also, that inside from the bottom there is not thread... is not a problem that if you turn the cylinder?
2. if you don't adjust the stiffing (thats a word?).. starts in 0 (cero) from factory?
kapo is offline   Reply With Quote
Old 09-27-2007, 02:35 PM   #75
Thirty-Nine
1) To lower/raise the car you turn the entire cylinder. You loosen the bottom red stop, and then turn the entire shaft accordingly. If you adjust the upper perches, you're going to increase/decrease your suspension travel, which is a whole nother adjustment.
2) I don't know where the factory settings were. I turned mine all the way to "S" or soft.
Old 09-27-2007, 03:57 PM   #76
kapo
Argentina Presente!
Drives: 07 White LB
how you turn the cyliiinder? by hand i guess.. but I can't do it.. :(
Old 09-27-2007, 04:53 PM   #77
Thirty-Nine
Undo the bottom red perch. If it still doesn't move, take a jack and put it under the conrol arm to take some tension off. I found that worked. I was having a hard time turning mine, too at first. This helped. And yes -- you do it by hand (wear gloves!).
Old 09-27-2007, 05:11 PM   #78
kapo
Argentina Presente!
Drives: 07 White LB
thanks! good advice!
now.. one thing.. i was playing arround with my setup, and i was able to raise or lower the car using the top spring perch... is possible if you can measure between the spring stop and the bottom stop? so i can put it at stock distance..
thanks!
Old 09-27-2007, 08:40 PM   #79
dsc_pat
track or die
Drives: Yaris LB CE CDM
thanks for all the info
asked if you had done mechanic before only to compare to myself..thanks !
let us know how stiff it is and how low you drop the car...can you go as high at stock height ? (or almost stock..) ?
dsc_pat is offline   Reply With Quote
Old 09-27-2007, 10:12 PM   #80
Thirty-Nine
Here's a pic of the Megans w/my Rays Engineering Texan Shot Guns (16x7 +37 205-50-16).
I need to either raise the rears or lower the fronts a bit, I think. Rubs a bit under cornering. I will say, with these sticky Yokohama ES100s, this thing is like it's on rails.
Old 09-28-2007, 12:07 AM   #81
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
looks great on those wheels with that drop
SPONSORED BY
Old 09-28-2007, 03:00 AM   #82
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
yay another yaris with an aggressive stance ^^
Old 09-28-2007, 10:11 AM   #83
03Z33
03Z33's Avatar
Drives: TCR10
Looking good! Glad you got it worked out in the end. Just sorry I couldn't give you more definitive advice... I must have assumed you had the strut bearing installed already.
03Z33 is offline   Reply With Quote
Old 09-28-2007, 11:38 AM   #84
Astroman
Modded Moderator
Astroman's Avatar
Looks good! I hate my wheel gap
Old 09-28-2007, 12:31 PM   #85
kapo
Argentina Presente!
Drives: 07 White LB
looks good!!!
Old 09-28-2007, 12:47 PM   #86
smokinyaris
smokinyaris's Avatar
Drives: bad boy
THAT SHIT IS ILL SON
smokinyaris is offline   Reply With Quote
Old 09-28-2007, 11:59 PM   #87
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
I use Megan coilovers and like them. I'm running them full hard in the front and mid in the rear. The 6k springs are pretty stiff in the back but good enough for the street and weekend track runs.
I plan on getting the front springs changed from the 5kg to 7kg for the track, but this will make it harder on the highway where the car bounces all over the place going into the mountains.
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 09-29-2007, 02:38 PM   #88
Thirty-Nine
I haven't yet cranked the dampening up yet. I'm still on full soft and it's still very stiff. I want to crank 'em up to full stiff just to see what it's like.
Old 10-20-2008, 01:34 PM   #89
ToTo
ToTo's Avatar
Drives: Toyota Yaris T SPORT
Looks really good, but lower the front a bit!
ToTo is offline   Reply With Quote
Old 10-20-2008, 04:19 PM   #90
Thirty-Nine
If I go any lower in the front, I'll rub like crazy. As it is now, I rub a bit in front with 195/55/15 tires and 15x6.5 (+40) wheels.
It's been over a year now, and I still really like them -- no problems.
Megan Springs? churp Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 06-06-2007 03:11 PM
Megan or Tein suspension elmercurrie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 43 05-31-2007 09:41 PM
Comp S Coilovers for a discount and installed BulletProofAuto California 1 05-12-2007 01:04 AM
cusco coilovers installed badhabitz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 02-03-2007 04:43 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
