Old 08-04-2011, 03:29 PM   #91
SAV912
Pirate Yaaaaris
SAV912's Avatar
^ Nice and thanks! Feedback and reviews are welcomed!
My understanding is that the short shift kit only shortens fore and aft movement, not side-to-side, as a "true" short shifter would. Glad you like the improvement!
Did you do the fluid too? That will further smooth out your shift feel.
The short shift kit only does fore and aft, you're right. You'd have to put another bracket on the other cable to decrease side to side movement, but I am impressed all the same.
And this is without the fluid yet as it still hasn't arrived. I am faster than UPS going through my neighborhood because the tracker said it was out for delievery at 9 this morning. They had a four hour head start, come on UPS!! Get it together!!
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 08-05-2011, 05:14 AM   #92
1NZYaris1
1NZYaris1's Avatar
I am still waiting for mine
buti still you Garm
Old 08-05-2011, 07:57 AM   #93
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
sounds like a great product...i'm still a little weary...i really like how stock feels in both cars
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-05-2011, 08:36 AM   #94
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
malibu,
you are a racer right? get the extender and the short shifter and you get the feel of stock but it is closer to the steering wheel. I did this just because I am used to trucks vs small cars. it is a good feeling.
that is just my 2 cents.
Old 08-05-2011, 10:35 AM   #95
If you like it as is, don't change it. For me, the Yaris reminds me of my old Karmann Ghia -- mushy, sloppy shifts.
Old 08-05-2011, 11:46 AM   #96
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
well, i had some more time today and went out to try to put the bracket on again. there were a few times trying to get the retainer clips off that i thought about quitting again, but i finally got it, ended up using pliers on the passenger side clip. after the clips came off, everything else was a breeze. haven't gone driving yet with the new bracket, but i'm heading out this afternoon and i'll see how it feels then :)
thanks for everyone's help with the install.
goliath1812 is offline   Reply With Quote
Old 08-05-2011, 01:18 PM   #97
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Grats on getting it done. You'll like the new feel (though for me it's going to take some getting used to - I still like it better than stock)
Old 08-06-2011, 04:19 AM   #98
KSIbucky
KSIbucky's Avatar
having problems with retainer clips how do i get them off??? please help
7 Color Tach
Fujita Intake
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
Old 08-06-2011, 08:39 AM   #99
BEEF
BEEF's Avatar
use a really big flat head screwdriver, place it inbetween the bent lip at the top of the retaining clip and the top of the cable (which happens to be metal) and turn the screw driver. this should wedge the retainer clip up. readjust the screw driver a few times and it should losten it enough to get it off. it helps if the tip of the screw driver is 1/2 to 3/4" wide. also depending on your screwdriver design, you can put a wrench around the handle and get even more torque in your twisting.
this may not be the BEST way to do it but it worked for me.
Old 08-06-2011, 12:48 PM   #100
^ That works, and so do channel lock pliers from the top.
Old 08-07-2011, 03:17 AM   #101
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
just installed today..2 hours of frustration.
I love the new feeling, even shorter shifts than before (full NST ssk kit).
Pics show the difference in height the cables sit.
Without the bracket, there was damage to the engine bay short shifter. The bearing bit into the side.
Check out my Build thread:
Old 08-08-2011, 03:06 AM   #102
KSIbucky
KSIbucky's Avatar
^now we have your finger prints. I'm going to rob some banks.
p.s. finally go the bracket installed
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 08-19-2011, 12:36 PM   #103
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Originally Posted by mazilla View Post
It's official, the prototype has been installed.
I installed the new Micro Image SSK on my 07 liftback last night!!
NEW BRACKET IN (FRONT VIEW)
NEW BRACKET + ADAPTER **UPON COMPLETION DON'T FORGET THE ORIGINAL WASHERS GO ON TOP OF THE BUSHINGS, I LEFT THEM OFF FOR THE PICTURE ONLY.
I noticed that you don't have the wiring harness bracket attached. On mine, there is one (labeled in blue):
Shouldn't there be one on your new MI bracket? I drew one in where it ought to be (in blue above the cable clips)...
I notice that you have an '07. Did they not have the bracket for that model year? Or did you skip putting it back in?
Old 08-20-2011, 10:31 AM   #104
goliath1812
Must have just not put it back on. The SSK bracket doesn't come with a new wiring bracket, but it does have a place to screw the old wiring bracket back on.
Old 08-20-2011, 10:39 AM   #105
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I just skipped putting it back...didn't even realize it. I'll take a look and see if it's necessary.
-Type 07 FFL-
My odometer 03/11
Old 08-21-2011, 12:49 AM   #106
1NZYaris1
1NZYaris1's Avatar
Finally Got mine Yesterday
thank You Garm
Old 08-21-2011, 01:02 PM   #107
Spidermandud
Spidermandud's Avatar
Drives: Black '08 Yaris Hatch S
Coooooooooooooooooooooooooool.
-Will-
Spidermandud is offline   Reply With Quote
Old 08-21-2011, 06:08 PM   #108
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
thank You Garm
Crap, that's where the Micro Image decal goes!? Why didn't Garm tell me? Now I have to pull everything back out to put the decal on...
TWM Shift Knob SALE Until July 15th! TWM Performance Sponsors Classifieds Area 6 10-30-2009 12:46 PM
NEW GROUP BUY: NST Short Shift Kit (NonStopTuning) NonStopTuning NonStopTuning 245 08-28-2007 03:53 PM
short shift: NST or TRD? cali yaris Performance Modifications 21 07-07-2007 03:38 PM
Feb Shift Knob Sale From TWM! TWM Performance Sponsors Classifieds Area 2 02-18-2007 10:15 PM
Having Trouble with TWM Short Shift Install. Need Help xfatefailsx07 Performance Modifications 3 10-10-2006 01:38 AM
