Old 03-22-2013, 03:14 AM   #1
skoya
skoya's Avatar
Drives: Yaris 1.0L
Dashboard Clock goes off?
Hi,
When I started the car this morning,the clock and BC indicator suddenly goes off.Anyone has idea what it could be??
skoya is offline   Reply With Quote
Old 03-22-2013, 03:36 AM   #2
jRoss
Drives: 2010 5spd sedan
Try the knob to the left off the steering wheel, turn it til it clicks
jRoss is offline   Reply With Quote
Old 03-22-2013, 04:40 AM   #3
skoya
skoya's Avatar
Drives: Yaris 1.0L
What knob?There is only for the mirrors and headlights
Old 03-22-2013, 06:42 AM   #4
jRoss
It's the like a spinny switch that adjusts the dimness of the gauge cluster, i believe it's right under the cup holder. I accidentally hit it one time and the clock light would go off when i turned on the headlights, i thought something was wrong. It took me taking it to autozone and a little experimenting.
Old 03-22-2013, 07:54 AM   #5
Most of the European ones do not have a dimmer rheostat like our US ones do.
What year is the Yaris?
And, does it have the digital or analog instrument cluster?
Old 03-22-2013, 08:22 AM   #6
skoya
skoya's Avatar
Drives: Yaris 1.0L
The Year is 2006,and the cluster is digital.
Old 03-22-2013, 09:14 AM   #7
OK - So definitely no dimmer rheostat.
Check the 7.5A MET, 7.5A PANEL1, and 7.5A PANEL2 fuses all of which are in the fuse panel that is under the bottom of the dashboard.
Old 03-22-2013, 09:42 AM   #8
skoya
skoya's Avatar
Drives: Yaris 1.0L
That is left under from the steering wheel,when I remove the panel,right?
Old 03-22-2013, 09:46 AM   #9
Yes - If your car is left hand drive it is to the left of the steering wheel and and it is under the bottom of the dash, so you look up from the floor to see the cover, which has the labels.
Old 03-29-2013, 11:12 AM   #10
That is the one that I have. I just disassembled mine and hooked it up on my test bench to experiment with it. The clock and odometer are a separate assembly from the rest of the instrument cluster. Does anything at all display on the clock area of yours?
Old 03-29-2013, 06:37 PM   #11
skoya
skoya's Avatar
Drives: Yaris 1.0L
No nothing.Did you find something that can be replaced,or behind that LCD is a small electronic board.Maybe there is a malfunction,somethin broken or burned?
Old 03-29-2013, 06:46 PM   #12
The small LCD (which is actually a vacuum fluorescent display) for the clock and odometer is a separate assembly, so that could be replaced as it may be the bad part. There are three separate circuit boards - The large main on, the one that the speedometer display is mounted to, and the "Core" board, which snaps to the back of the large board. The Core board contains the primary processor for the cluster and it has the EEPROM where the odometer data is stored. Unfortunately you can't buy the boards separately from Toyota, but if you can track down one from a wrecked Yaris, which has a cluster with the same part number, then you can either swap the clock/odometer display onto yours or you can swap your core onto it.
Old 03-29-2013, 06:58 PM   #13
skoya
skoya's Avatar
Drives: Yaris 1.0L
Yeah,but used clusters cost over 100$ on ebay,so it is a bit expensive.My dad is a electrician,so i wil disassemble the cluster and give him.Maybe he can find the problem.Anyway thank you for your response,i will notify you if i find something.
Old 03-29-2013, 11:03 PM   #14
It looks like there is one driver for both the small VFD and the large one, so my bet is that it is the VFD itself. I have a couple of right hand drive Japanese digital clusters that I pulled apart a while back. I noticed that the small VFD is identical between the JDM RHD one and the European LHD one. I swapped one of the JDM ones into the European cluster and it works fine. I have a couple of them, so if you want to try one let me know.
Old 05-24-2018, 10:51 AM   #15
lespaulstd
I am facing the same issue and will try to replace the clock from a donor cluster. In order to test the "new" cluster, can somebody point me the pinout of the connectors to be able to switch it on and see if the clock works?
It is an European Yaris, and part-number is 83800-0D660
Attachment 50263
Thanks in advance
lespaulstd is offline   Reply With Quote
Old 05-28-2018, 11:40 AM   #16
GTJos
Drives: Yaris 2006 + CorollaVerso 2002
Hi all !
Same problem (for over a year now...)
Happy to find this forum/threat. Are there any real solutions yet ? Thank's in advance !
GTJos is offline   Reply With Quote
Old 08-07-2018, 08:27 AM   #17
lespaulstd
Thanks in advance
Searching this document from this post of CTScott I've been able to check that the donor cluster works.
It is only necessary to connect, pins 1 (12V) and 24 (GND) to power the unit outside of the vehicle. Now my plan is to swap the clock/temperature display of both units.
Old 03-31-2013, 06:39 PM   #18
That black spot does appear to be a normal part of how they manufacture the VFDs.
Since it is custom I can't find a data sheet for it. It would have been good if I could so that we could take some comparative measurements to determine if that is what is bad on yours.
GI: "YarGauge" replacement clock module (Digital Tach, etc.) CTScott Items for Sale by private party 756 03-21-2013 09:22 PM
05 Echo changing time on clock jambo101 DIY / Maintenance / Service 3 11-12-2011 05:34 AM
Dashboard mount for iPhone 4S? shima In Car Entertainment + Electronics (audio / video / alarm) 3 10-25-2011 10:22 AM
Dashboard remove ... ALL of it Toji Cosmetic Modifications (Exterior/Interior) 7 02-26-2011 07:30 AM
Setting the clock after DST change ToddR DIY / Maintenance / Service 10 03-10-2009 12:33 AM
