Old 03-10-2013, 10:17 AM   #1
mr_miles
Drives: 2013 Yaris
I love this thread. I wish I was closer so that i could help :/
Old 03-10-2013, 03:40 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
That would be lots of fun...
Well, at least I can keep you posted every step of the way. I just ordered a part for the manifold plenum, and will post pics when it arrives. It's something which has absolutely no relation to engines, and I'm adapting it to an unintended purpose.
As far as I can tell from searching the web for everything about intake manifold design I could find... no one has built the design I'm going to try. There may be a reason. Because it doesn't work! But I'm going to find that out for myself. I'm building one manifold designated for testing only. And the good part is that if the experimental designs don't show any gains on the dyno, I can always simply cut them off of the runners and try something else.
Old 03-10-2013, 05:06 PM   #3
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
If you are going to try a really large diameter plenum...large diameter equals low velocity.
Old 03-10-2013, 06:06 PM   #4
tooter
play every day
tooter's Avatar
No, I won't be doing that. First off, there's no room for a larger plenum with this particular manifold design while keeping the air filter under the hood. And second I don't want to go larger. Instead, I'm going to a smaller plenum. The existing one is already almost non existent with that big thick intake tube occupying so much volume...
...and yet that design works great! I believe it is because of the unique configuration with all the runner entrances pointing directly at the bore of the throttle body...
That internal intake tube terminates only a couple of inches in front ot the runner's entrances. So there is very little plenum volume left over.
When I get the part, I'll be able to measure exactly how much smaller if at all by filling both plenums with water. What will be radically different is the profile of the new plenum. I literally dreamed up this crazy idea...
Old 03-11-2013, 08:17 PM   #5
Cool Tooter! Are you reworking the manifold with your own plenum and TB mount?
Old 03-11-2013, 09:44 PM   #6
tooter
play every day
tooter's Avatar
Yes.
I have a totally "outside the box" idea and am going to build up a tooter and dyno it just to see how the concept works.
Old 03-15-2013, 04:16 PM   #7
tooter
play every day
tooter's Avatar
The new plenum came today, and it has nothing to do with intake manifolds. It's a structural architectural ornament. This is the basic layout of the experimental tooter...
I filled up both plenums with water to test the volume, and was totally suprised to discover that they both hold exactly 26 ounces! I'm always looking for omens and this is a really good one...
The old plenum appears to be a lot larger because there is so much material inside it which by displacement decreases the volume.
Old 03-15-2013, 04:50 PM   #8
Phallic!
Old 03-15-2013, 06:21 PM   #9
tooter
play every day
tooter's Avatar
To you, everything is phallic.
Old 03-15-2013, 10:01 PM   #10
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Hmm, what about the 6" tube remnant?
Old 03-15-2013, 11:14 PM   #11
tooter
play every day
tooter's Avatar
It's right here...
I think I'll try it without this time since the two plenum volumes already match. I can always cut off the hemisphere and add a ring later. And while the plenum is off I can clean up and smooth out the runner entrances.
Old 03-16-2013, 11:58 AM   #12
CrankyOldMan
Yikes, those are some gnarly welds for a flow surface.
Thinking back to my own can-shaped design, the flow analysis showed that there was pretty much no air movement in the shoulder area of the TB side.
Old 03-16-2013, 12:33 PM   #13
tooter
play every day
tooter's Avatar
Well, remember that it was just a mass produced Corolla manifold and not a high performance racing component. The welds are actually well controlled, but I do think I can improve the runner ports with the trusty old Dremel... something that no manufacturer would take the time to do because there's no return on investment.
Old 03-18-2013, 11:28 AM   #14
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
they welded them like that for easy access & it smooths out the lip that would be there if they were externally welded
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-18-2013, 11:51 AM   #15
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
^ that and it would be next to impossible to weld them externally.
Old 03-18-2013, 12:12 PM   #16
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Interesting... whats the next step??
JustDidIt is offline   Reply With Quote
Old 03-19-2013, 11:33 AM   #17
malibuguy
Obsessed with 1.5L
procharger
-96 Tercel 4dr
Old 03-19-2013, 12:07 PM   #18
tooter
play every day
tooter's Avatar
I don't exactly know just yet... I'm thinking about it while finishing another regular tooter.
For sure, I'll need to have a plain throttle body base plate made and figure out a way to attach it securely as the aluminium hemisphere shell is pretty thin. I was thinking of a short bellmouth on the inside like this extending a couple of inches into the center of the hemisphere directly aligned with the axis of the 4 runners so the flow is a straight line.
The throttle plate will use the same CNC information for the outer surface minus all of the adaption machining. It'll be one inch thick to raise the throttle body enough for the chip to clear the hemisphere.
Here a flow simulation for a bell mouth...
http://www.youtube.com/watch?v=jFwo_3IxZyo
If it works one way... it'll also work the other.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
