Old 05-11-2013, 11:47 AM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
More like this...
I've always loved trains so I built my own little backyard riding railroad. It took a year and a half to lay 200 feet of rail. I designed and built this pull cart.
It's a blast to ride because the grades are as steep as 7% making it as much of a rollercoaster as a train.
The neighborhood kids love it too.
Old 05-11-2013, 12:21 PM   #2
TOLMACH
Drives: soarer
^ WOW!
Old 05-11-2013, 12:33 PM   #3
tooter
play every day
tooter's Avatar
This will give you an idea of the grades. Had to do a lot of testing while laying the rails to make sure they were safe to ride.
http://www.youtube.com/watch?v=gTI3NVYO9DY
Old 05-11-2013, 03:14 PM   #4
yeah, that's pretty cool. You've made a lot of progress since the earlier videos.
What controls the speed besides the track itself? Brakes?
Old 05-11-2013, 03:48 PM   #5
tooter
play every day
tooter's Avatar
Gotta have brakes on this railroad or you die!
Both geared axles are chained together so when the brake pads press against the front wheels, and rears also slow down.
Old 05-12-2013, 05:16 PM   #6
jetblast
Drives: Gen 1 XB
How about Fred Flintstone Feet!!!! Yabba Dabba Dooo! C'mon ride the train, choo, choo, rowdy.....boomsha, boomsha the song is now stuck in my brain.
And now I'm tryin' to remember who sang it! ADD can really be a pain. Squirrel!!!!!
Why strive for a JDM BB, when you can promote the Scion badge?
jetblast is offline   Reply With Quote
Old 05-13-2013, 05:54 PM   #7
tooter
play every day
tooter's Avatar
I tried a few wild rides on the flat car using "foot brakes". Too much velocity and I just get thrown off when the flat car hits the curves at the bottom of the hill.
The entire line of tooter products is now back in stock.
tooter manifold: $450 + free shipping
tooter build your own manifold kit $265 + free shipping
tooter supercharger 1zz throttle body base adaptor $185 + free shipping
Old 05-13-2013, 07:21 PM   #8
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
How much does the mani weigh ?
Ryze268 is offline   Reply With Quote
Old 05-13-2013, 09:11 PM   #9
tooter
play every day
tooter's Avatar
It weighs 7 3/4 pounds...
I'm pretty sure I had done a comparison with the weight of the stock manifold. It's likely buried somewhere in this thread but I couldn't find it.
The power gains from the back to back comparative dyno run charts are:
tooter manifold + stock 1NZ throttle body: +3.4hp +1.3tq
tooter manifold + 1ZZ throttle body: +6.6hp +2.8tq
All the figures are rounded down to the nearest tenth so as not to falsely enhance them.
Old 05-13-2013, 09:21 PM   #10
Ryze268
Ryze268's Avatar
Depending on how the 'ole pay check looks, I might be placing an order at the end of this month
You should start a fresh thread =P
Old 05-13-2013, 11:54 PM   #11
tooter
play every day
tooter's Avatar
No problem, there's no time limit. I'll always be keeping a small inventory of all the parts whatever you decide.
Old 05-14-2013, 08:31 AM   #12
thefalls
Drives: Axio GT
Has anyone tested this manifold "Tooter" on a boosted motor ?
Thanks.
thefalls is offline   Reply With Quote
Old 05-14-2013, 09:48 AM   #13
3cyltrbo
Sorry I don't want to read back through the entire thread:
-What about finishing / can you offer powdercoating or polishing?
-remind me again, will I have problems installing this in a 2010 5spd hatchback with an AEM CAI? (including a 1zz TB that I have already)
-you've been showing one with a new design (the alien looking end thing) - its pictured below and you mentioned it in post #1191................................... when will this version be coming out? (you called it the ET)
Cheers
Will
ntr1_1@hotmail.com
3cyltrbo is offline   Reply With Quote
Old 05-14-2013, 10:19 AM   #14
tooter
play every day
tooter's Avatar
I totally understand... it's kinda huge.
No, however the manifold comes stainless steel bead blasted and ready to accept any finish you'd like to apply.
The tooter manifold relocates the throttle body about 2 inches to the right from the stock location. So if your intake has enough room to move about 2 inches, you'll be fine. This is how the throttle body looks with the stock air box.
Here you can see the difference in the throttle body's orientation from stock by its relation to the stock air box. 2 inches were trimmed off of the stock rubber intake tube to make it fit the stock air box. Your CAI's mounting point locations would be different as well as the location of the filter in your fender well so it would definitely need to be modified. Shortening it a couple of inches and adding a silicone coupling would likely work.
Cheers
Will
ntr1_1@hotmail.com
Right now the tooter et is just a crazy experiment.
I'm going to build it, dyno it, and drive around with it on my Yaris just to see how it works.
Old 05-14-2013, 12:06 PM   #15
tooter
play every day
tooter's Avatar
Thanks.
No. The only boosted ones I've ever seen were guys in Puerto Rico who had the original idea.
There's one pic of another one, but I haven't been able to find it yet. I think it would shine in a forced induction setup because it can handle pressure and has a higher flow capacity. That would shift the power limiting factor to how much flow the head could handle.
Old 05-14-2013, 02:56 PM   #16
tooter
play every day
tooter's Avatar
Found an example of the next idea I'd like to try...
...a manifold with no plenum.
Old 05-14-2013, 03:09 PM   #17
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Will you use individual velocity stacks for each runner?
JustDidIt is offline   Reply With Quote
Old 05-14-2013, 03:54 PM   #18
tooter
play every day
tooter's Avatar
I'm just rounding and smoothing the openings that are already on the manifold like the one on the upper right.
The exit of the main intake tube that feeds the four runners is a bellmouth profile rounded to 180 degrees. I'll be cutting a hole in the hemisphere when I determine the right angle for the throttle body to set. The round base of the plenum has an advantage in that it can be rotated to generate just the right attitude for the throttle body to set. Then when that has been determined, the position can be indexed and the sphere can be welded into place.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
