#1 |
Intake manifold notes and specs from today. As always, you can count on full disclosure and 100% information when we have something to show you.
I'm pretty happy with the results. Our manifold made some nice power in the 3000-5000 rpm range, where most people will use it well. With some tuning, the top end will yield some power as well, AFR went pig rich at 5500+ ambient temperature was 90 degrees F 87 octane (91 would have helped us) tested on a stock Yaris Engine and bay were hotter for the pulls with MI manifold Dyno Dynamics (tough dyno with numbers, 10-15% lower than DynoJet) ***some changes and improvements to be made in production rich on top -- will deliver more power with some tuning no CEL's sounds badass ![]() Here is the dyno chart (sorry for the large image). Grey is MI manifold, the other line is stock plastic mani. Chart shows power and torque comparisons. ![]() here's a YouTube vid: http://www.youtube.com/watch?v=IIMXX8bw8lE |
Do you have the AFR graph as well?
#3 |
We did not have a chance to test it with the 1ZZ throttle body today, but that probably would have helped a bit more. Just a guess. Future dyno session for sure.
#4 |
bluevitz, yes, I'll post that next.
#5 |
#6 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Im liking this.
1zz tb and tune damn skippy
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#7 |
![]() ![]() Drives: 2007 3dr hb 5sp Join Date: May 2012
I wonder why the ecu decided to go so rich? I guess a tune will squeeze a bit more out.
#8 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Congratulations, Garm! It looks like a really nice fat torque curve.
In what gear did you run it? My runs took about three times as long as your dyno video! Also what intake did you run on the throttle body. It was difficult to make it out in the video.
#9 |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
I can't wait to buy one and install it with a 1zz tb. Any plans to try it out on a yaris with some mild mods? Id love to see how this does on a car with i/h/e and a 1zz tb.
#10 |
^ I sure want to or with a Zage kit at low boost.
I think I'll throw one on my car with a 70mm TB and see what it pulls too. Let's see what 25 psi does to it.
#11 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
-Derrick- "Racing is important to men who do it well. When you're racing... It's life. Anything that happens before or after, is just waiting." |
#12 | |
![]() ![]() Drives: Axio GT Join Date: Apr 2012
Of course there will be gains over the plastic one. Well lets find out with the boosted motors. I better start saving! |
#13 |
3rd gear pulls. Simota air filter (I think) on stock throttle body/MAF tube. (the rubber tube that feeds the stock airbox).
we tried pulls with and without air filter attached -- made no difference in power/torque at all. |
#14 |
play every day
#15 |
Obsessed with 1.5L
Toyotas always seem to dump fuel on the top end. My tercel before the turbo would go to 10.3-10.5 range for the last 1200rpm...i called it Evo style...just blowing out black smoke.
Its also why i can get away with mild boost with no tuning...im still 11.6~ on the top end
#16 | |
Drives: lil red 5-door Join Date: Sep 2006
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
#17 |
Thats wild. As piston speed increases the likelyhood of autoignition decreases... maybe the ecm is throwing a lot of advance at that part of the curve too.
#18 | |
Obsessed with 1.5L
I used to run one oy old malibus at 15* initial and 44* total...ran awesome too
| Mid-West Chapter Micro Image Car Club | lilredrocket | Southwest | 10 | 10-05-2009 01:06 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| Yaris Intake Manifold | richardholdener | Performance Modifications | 201 | 05-18-2009 11:58 AM |
| Intake Manifold Gasket? | Nexus1155 | DIY / Maintenance / Service | 6 | 11-18-2008 08:03 PM |
| Official Richard Holdener *MID-RANGE* Intake Manifold List | WolfWings | Performance Modifications | 59 | 11-13-2008 11:26 PM |
