Old 08-20-2013, 06:26 AM   #127
Originally Posted by xboxer View Post
Same question as above, including the OEM Stalk CC Pin Kit, and Cruise Control Indicator Module. Please send PM. Thanks
PM sent
Old 03-18-2014, 12:08 AM   #128
Tylard
Drives: 07 Yaris
Interested in purchasing
Do you still have any these?
07 sedan m/t. Cost as well. Thanks
Tylard is offline   Reply With Quote
Old 03-18-2014, 06:20 AM   #129
Yes. PM sent.
Old 03-18-2014, 12:04 PM   #130
nortonfb
Drives: 2007
Please send me the pricing & payment info also.
I have a 2007 hatch. Does your kit include everything necessary?
Thanks
Nortonfb
68 Norton fastback
(Steve)
nortonfb is offline   Reply With Quote
Old 03-18-2014, 01:29 PM   #131
Thanks
Nortonfb
68 Norton fastback
(Steve)
PM Sent. The kit includes everything necessary, other than the tools to do the install.
Old 03-21-2014, 09:52 AM   #132
z0mb13k1ll
z0mb13k1ll's Avatar
Drives: '15 Dodge Challenger
ive got a 2007 sedan, can you pm me with the price and what i would have to do to install? thanks
z0mb13k1ll is offline   Reply With Quote
Old 03-21-2014, 10:34 AM   #133
PM sent
Old 03-22-2014, 07:11 PM   #134
Tylard
Drives: 07 Yaris
Super fast shipping, install not too bad, fishing the wires was def the hardest part. But I cant seem to get it to function on my 07 m/t sedan. I have tried rechecking all the connections and triple check the clutch switch to ensure it is fully pressed in when the my foot is off the clutch pedal.
Any suggestions of what to check?
My wire coming out of pin 40 on the ECM is hooked up and ran through the firewall. I connected this directly to the wire coming out of the slot 1 of the D3 connector. Is this ok or do I need a different wire? If so what is it where do I get it
Old 03-22-2014, 07:17 PM   #135
Double check your pin 1 and pin 2 locations per my DIY (http://www.yarisworld.com/forums/showthread.php?t=33750)
Also, with the ignition switch in the ON position, you can measure the voltage on the pin1 wire and will see 12V if it is connected properly. (Pin 1 is the one that goes to pin 40 on the ECM connector).
Also, double check your pin 40 to make sure you didn't install it on the opposite side of where it belongs.
Old 03-22-2014, 09:02 PM   #136
Tylard
Drives: 07 Yaris
Checked pin 1 and 2 and Im happy with them. Rechecked pin 40 also happy with that.
Checked the voltage. I put my red lead on the connection between the pin 1 wire and the pin 40 ecm wire. Then I put my black lead on the bolt where pin 2 from the d3 connection is mounted. I get 12 v with the ignition turned on. Holding and toggling the cruise on/off switch does NOT make change and still reads 12 volts.
Where the pin 2 wire is mounted there is a black lead already connected to that, I just added on the pin 2 wire and put the bolt back on.
Old 03-22-2014, 09:49 PM   #137
Ah, the pin 2 wire is the "other side". It is the ground for the system.
The black wire is not pin two. It is in the opposite row from pin 2. In this picture you can see the blue wire in pin 1 and the brown in pin 2:
Old 03-22-2014, 09:58 PM   #138
Tylard
Drives: 07 Yaris
My D3 connector looks just like the one pictured. The wires sent are different colors but going off the colors shown in the picture. The blue one connects directly to the A21 pin 40 wire. The brown one goes to a bolt (for grounding).
Old 03-22-2014, 10:00 PM   #139
Tylard
Drives: 07 Yaris
"4.8. Splice the ECM pin wire to the piece of 18-22 AWG wire using a butt splice or
solder and heat shrink tubing."
Do I really need to do that because the wire you sent me is long enough to reach the D3 connector.
Old 03-22-2014, 10:08 PM   #140
No. They are long enough to reach with how I ship them now.
Old 03-28-2014, 07:14 PM   #141
Tylard
Drives: 07 Yaris
Got the issue resolved, I now HAVE CRUISE!! Pretty sure this just doubled the value of my car. So happy about this.
Old 03-28-2014, 07:15 PM   #142
Tylard
Drives: 07 Yaris
And buy your stuff from CTScott. He does all the BS work so you don't have to and everything comes ready to hook up. Fast shipping, good customer service, and it was pretty fricken cheap too. Scotts the man.
Old 05-26-2014, 02:51 PM   #143
OldTimer
Drives: 2008 Yaris
I ran across this forum while searching for a solution for a Yaris without cruise.
I'm needing to make twice weekly 250 mile trips and unfortunately am finding it
difficult keeping a constant speed with old worn out feet and legs.
I have an 2008 Yaris hatchback (base) with a manual transmission.
Are the cruise control kits still available?
Thanks
OldTimer is offline   Reply With Quote
Old 05-26-2014, 06:20 PM   #144
nortonfb
Drives: 2007
CT Scott has them. Drop him a PM.
Steve
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
