Old 01-29-2017, 08:38 PM   #145
dogsridewith
Drives: 2007 2-door hatchback
manual transmission oil
Originally Posted by Aclosefriend View Post
Thanks for this. I bought a 08 Hatchback a few months ago with a 5 speed MT with 65k miles. This was so easy and the shifting is much much smoother now. Only took 20 minutes, and most of it was waiting for the fluid to drain and for the fresh thick gear oil to flow down the tube.
Which oil did you go with?
Old 07-22-2018, 02:47 AM   #146
Rigo93shred
Drives: 2009 red 2 door hatch yaris
I just got a yaris 2 door hatch 5 speed with 105k miles and idk if the tranny oil has ever been changed it shifts nice never had a standard but i dont hear grinds or anything in mine the previous owner had it for 3 years and never mentioned trany oil change should i change it along with all fluids just to start fresh or would new oil mess up my tranny cuz its good i sort of cant stand not knowing if its clean or not and if its never been changed should damage happen to it???? Sorry for the long post 1st car and i wanna baby it good
Rigo93shred is offline   Reply With Quote
Old 09-07-2018, 08:33 AM   #147
timbstir
Drives: 2010 Yaris Seden
So I did my gear oil yesterday and I took the fill plug off first, and when I did oil started to pour out (less than a quart), did this happen to anyone else?
timbstir is offline   Reply With Quote
Old 09-07-2018, 09:03 AM   #148
That is fine it just likely wasn't overfilled before due to the front end being jacked up higher than you had it.
FWIW I over fill my trans fluid by about half a quart
Old 09-07-2018, 10:02 AM   #149
Not much came out when I did mine. Had a flat surface though.
Then poured 2qt in, small quantity came out and that's what I left it at.
Sent from my VTR-L09 using Tapatalk
Old 09-07-2018, 01:43 PM   #150
timbstir
Yeah it wasn't much that I had pour out, it was up on jack stands. The worst part was that I wasn't anticipating it so I didn't have a catch pan ready at the time so I had to spend the next half hour trying to clean my friend's garage. I put in about to quarts on level ground afterwards and it seems to be doing fine, it shifts way smoother than before.
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 01:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
