Old 10-28-2008, 11:42 AM   #1
Smokey159
Drives: Yaris Liftback
Need help with Tein spring install...
I bought a set of used Tein S-Tech springs.
I need pics of them installed from the underside.
I need to find out which end is up, and I need to know what the instructions said for the recommended cut is on the bumpstops.
I looked on tein's website, but the install instructions page comes up with "page not found".
Thanks in advance.
Smokey159 is offline   Reply With Quote
Old 10-28-2008, 11:57 AM   #2
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Thanks in advance.
Flat side of the springs go to the top,
Cut the bumpstops just below the plastic piece in the center, which is cutting off about an inch.
Old 10-30-2008, 09:37 AM   #3
Smokey159
SOLUTION FOR BUMPSTOP CUT
OK, I got the official word from Tein on this issue.
The S-Techs require that 1.4 inches be cut off the end using their "A" cut method. They have 4 different ways to cut bumpstops, the different methods can be found in the tech section of their website.
Can't believe I'm modding a Yaris, I must really miss my STi...
Old 11-02-2008, 11:41 PM   #4
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
Have fun Modding your car. And yes. I think you really are missing your STI.......
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 11-04-2008, 02:13 AM   #5
nerd_vitZ
Drives: 08 silver streak mica LB
i just looked at the words on the spring itself. up = up?
nerd_vitZ is offline   Reply With Quote
Old 11-04-2008, 03:10 AM   #6
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
^ if you could read the words from the spring then you're installing it correctly!
Old 11-04-2008, 06:39 PM   #7
thewifesyaris
thewifesyaris's Avatar
Drives: 2007 and 2008 MM Yari LBs
A pic of mine from a while ago.
Two Yari on home!
thewifesyaris is offline   Reply With Quote
which spring is better..Tein or Tanabe DF? seanele Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 08-09-2007 01:35 AM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
Camber after spring install dallas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-22-2007 02:57 AM
Tanabe NF210 spring install help Jerkratt Performance Modifications 8 06-08-2007 10:13 AM
