Old 10-28-2008, 04:46 PM   #1
kou
Drives: 08 lb
DIY sealing the hood.
so many asked so you had me out in the rain today. nissan part#66830-50Y00 this only comes with 11 clips the white one's in the picture i am sure you can order some more i used a total of 17 clips. the strip was a little long so i cut it down to 42'' after i had it attached. drill holes are 3/16'' i didnt really space the holes any special way just how i thought it would hold the best,i did one hole at a time and snapped it in place as i was going along. you will have to respace the clips make some new holes in the rubber,but is is pretty simple just dont make the holes to large it will stretch over the clips.
Old 10-28-2008, 04:52 PM   #2
May I sugget that everyone use tape where you drill to avoid any blistering of the paint, just as a precaution. Good luck everyone, nice job indeed
Old 10-28-2008, 04:55 PM   #3
kou
Drives: 08 lb
i thought about tape but my drill went through that bumper like butter.
Old 10-29-2008, 12:56 PM   #4
Newyaris
Newyaris's Avatar
Drives: New Yaris (02/2007)
Smile
Nice!
Newyaris is offline   Reply With Quote
Old 10-29-2008, 02:35 PM   #5
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
what is the benefit to this?
Old 10-29-2008, 02:56 PM   #6
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
looks better and if you got a cone filter it keeps water from going in during rain and being sucked in to your airfilter.. with the air and everything...
Old 10-29-2008, 03:24 PM   #7
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
ah.. maybe i'll do this at some point then.. once i get the SRI
Old 10-29-2008, 09:30 PM   #8
auxmike
auxmike's Avatar
How much was the strip? Where did you buy the extra black clips?
Old 10-29-2008, 10:01 PM   #9
Appalachian Trail 2007
Appalachian Trail 2007's Avatar
Drives: 2008 Yaris LB
what's that license plate holder thingy doing there?
3,441,567,453 posts BH (Before Hack)
Appalachian Trail 2007 is offline   Reply With Quote
Old 10-29-2008, 10:19 PM   #10
kou
Drives: 08 lb
the strip was cheap i dont remember i used to work at nissan,the extra black clips were off another seal i had laying around.
the license plate thing was something i made when i was bored.
Old 10-30-2008, 12:38 AM   #11
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Nice clean job... But, there are plenty other ways water gets under your hood. Are your going to seal those up to?
Old 10-30-2008, 01:14 AM   #12
kou
Drives: 08 lb
i have custom under panel i am just trying to figue out the lights.
Old 10-30-2008, 09:32 AM   #13
IsLNdbOi
IsLNdbOi's Avatar
Anyone know if they make white rubber strips like this?
Old 10-30-2008, 09:43 AM   #14
PetersRedYaris
Also, people could use this if they don't want to drill. It has 3M double sided tape to hold it in place...
It's actually truck tailgate seal and can be found for about $30 a roll (probably 2-3 Yaris hoods worth). The density feels about the same as the factory rubber seals around the doors. I keep a roll around as you can use this stuff for lots of things...
Old 10-30-2008, 10:42 AM   #15
IsLNdbOi
IsLNdbOi's Avatar
Wow, they actually make kits for this:
http://www.jcwhitney.com/Weatherstripping/600003813.jcw
http://www.jcwhitney.com/Body-Hood-W.../600003815.jcw
Not sure what "fender beadings" are, but they come in different colors:
http://www.jcwhitney.com/EMPI-COLORE...3815_10101.jcw
Old 10-31-2008, 10:08 PM   #16
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
Does this affect closing the hood? Do you have to use a bit of force? Are you able to reach the latch when you open the hood?
Old 07-30-2009, 04:28 AM   #17
RedRide
RedRide's Avatar
The Yaris is the first car I ever owned that didn't have a front hood seal.....another corner cut by toyota.
Anyway, sealing the front of the hood should keep the upper enginer bay a bit cleaner especially if you drive alot in inclement weather.
I have an idea about using something that will be a custom fit, will fill the gap and be real easy to to install.
I will keep Y'all posted about this.
Old 07-30-2009, 04:45 AM   #18
Can't you also use garage door bottom seal?
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
Micro Image Hood Design Contest cali yaris Micro Image 209 10-04-2009 02:49 AM
DIY hood lift brackets churp Items for Sale by private party 10 07-23-2007 06:37 PM
DIY Hood Cylinder churp Cosmetic Modifications (Exterior/Interior) 46 06-25-2007 05:46 AM
Before you buy . . . check that hood! woof General Yaris / Vitz Discussion 4 12-02-2006 05:14 PM
