Old 10-30-2008, 11:50 PM   #1
NonStopTuning
Lightweight Flywheel for the Yaris?
What options are currently out there?
Would anyone be interested in a very high quality lightweight option from NST?
Price would probably be in the neighborhood of $350-$400 and weight reduction would probably be about 35%.
Should we plan to move forward with pursuing something like this?
MIKE @ NST
www.NonStopTuning.com
Old 10-30-2008, 11:59 PM   #2
Fidanza makes one for us, I have it in my car. They are about $300. Go for it, Mike, and let me test it. I'll probably drop the trans anyway to put xB gears in soon.
Can you make us a gear set too?
Old 10-31-2008, 12:05 AM   #3
NonStopTuning
Hmmm... interesting
MIKE @ NST
Old 10-31-2008, 12:10 AM   #4
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i wouldnt mind one later. it looks like your products are good so if you end up making one i will more than likely buy it from you.
Old 10-31-2008, 12:20 AM   #5
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
+ Spec makes one
http://www.wesellcarparts.com/store/...idproduct=5453
Old 10-31-2008, 01:13 AM   #6
they sure do; haven't seen that one before. $300.
Old 10-31-2008, 01:14 AM   #7
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Mike: I'll take an NST flywheel any day of the week. Go for it!
Old 10-31-2008, 02:24 AM   #8
Jerkratt
Jerkratt's Avatar
haha funny im so right now lol but MIKE IF U DONT MAKE THIS IM BOYCOTING U GUYS!!!!
j/k j/k
im deff in for the flywheel and/or gears...
"It hurts more when its wet"
Old 10-31-2008, 03:50 AM   #9
pinoypizzaboy
Drives: 08 toyota yaris LB
what does a lightweight flyweel do anyways?
pinoypizzaboy is offline   Reply With Quote
Old 10-31-2008, 07:24 AM   #10
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
why not send whooppie one to test out with his supercharger setup he's installing.....
Old 10-31-2008, 10:24 AM   #11
d1nzfe
Drives: 1NZ-FE
Can NST do custom work?
Can i send in a pulley that u dun produce and custom make one??
d1nzfe is offline   Reply With Quote
Old 10-31-2008, 11:38 AM   #12
NonStopTuning
YES! In fact, we build custom pulleys all the time. Please feel free to look for me on AOL Instant Messenger at the screen name "NSTonAIM" or give us a call at 281-917-0221 should you wish to chat about a custom pulley.
For everyone else... please keep the discussion going regarding flywheel options...
MIKE @ NST
Old 10-31-2008, 11:38 AM   #13
NonStopTuning
j/k j/k
LOVE IT
MIKE @ NST
Old 10-31-2008, 04:41 PM   #14
Callisto
Callisto's Avatar
Drives: '08 Hatch
It is a matter of rotational mass. Most of what a flywheel does is providing inertia to keep things running in between cylinder firings. With a heavy flywheel, you get smoother operation, because of increased rotational mass carrying more inertia, BUT it takes longer for the engine to run up to speed, and it always has to be doing more work to keep the mass of the flywheel spinning. If you lighten the flywheel, you make it easier for the engine to spin up to speed, but also remove some of the smoothness of operation, especially in cars that are use primarily for street driving. When you let off the power, the engine will drop down in speed faster. This can lead to herky-jerky (a highly technical term ) operation. It is a balancing act when weighting the flywheel, you want it heavy enough to be smooth, but light enough to provide responsive performance.
Callisto is offline   Reply With Quote
Old 10-31-2008, 04:43 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
does xA/B/Echo work? it should, right?
if so, i heavily recommend Fidanza (not taking away from NST of course)
Old 10-31-2008, 04:50 PM   #16
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Flywheel for the xA/xB/Echo = Flywheel for the Yaris
Clutch components are also interchangeble
Old 10-31-2008, 04:58 PM   #17
whooppee777
DO IT!
Old 10-31-2008, 08:15 PM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
then i would 110% recommend my setup:
Fidanza flywheel
Spec Stage 3 clutch. overkill for most situations, yes.. heavier than a stage 1 but lighter than a stock clutch. 100% streetable. not a on/off switch yet it's held 12psi of boost (guessing 180whp +)
lightweight flywheel from fidanza dngz Performance Modifications 34 02-03-2009 11:02 PM
