#1 |
amp/sub cutting out need help!!
i have a jvc kd g430 and a 4-channel 300.1 phoenix gold amp for a 12" kicker, i have everything wire properly - ithink - and it sounds good right til the point where the amp turns off frequently, i dont understand this problem, can some one please tell me what to do? do i need a cap???
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
might be over loading.. the ohm load right?
Sold the yaris... rocking an 89 vw cabriolet now :) |
#3 |
aka SDMF
maybe amp getting 2 hot? or your wires are reversed
#4 |
![]() ![]() Drives: 2008 blazing blue yaris LB Join Date: Oct 2008
how are the speaker wires wired from the sub to amp? bridged or stereo, is the sub dual voice coil? 2 ohm or 4 ohm?
http://cardomain.com/ride/3151056 ![]() ![]() mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch coming soon: window tint, custom sub grills, tach and........ |
#5 |
im pretty sure its bridged. its not dual voice coil, and i dont remember which ohm it would be. ill have to take a look at it... could that be my problem? that im overloading it? sometimes the sub with have a minor popping sound too.
#6 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
phoenix gold 300.1 is a 4 channel amp ?
#7 |
[QUOTE=IllusionX;179183]phoenix gold 300.1 is a 4 channel amp ?[/QU
sorry it says on the amp Q X 300.4 Last edited by SweetRS; 11-20-2008 at 10:03 AM. |
#8 |
sorry it says on the amp Q X 300.4 ![]() and this is the sub, its a kicker f12a (thats whats it says on the sub itself)
#9 |
Tiny Giant Clothing
#10 |
Tiny Giant Clothing
its not made to run mono... that might be the reason
edit.. maybe it is. weird they dont put the rating for the mono in the specs
#11 |
yeah i might change the amp anyway, the sub is 4 ohms and im only using 1 out of the 4 channels. and it says that if its only 2 channel than its will be 2 ohms, im not a genius and i dont really know what that means or whether its a bad thing....what do u think??
there are three rca plugins on the amp. front, rear, and output. my rcas and plugged into the "front" plug in, although its plugged into the "rear" rca plugin on the deck, i get bass from the sub, just im tired of it turning itself on and off numerous amount of times when i drive. There is a switch on the amp so that u can switch from front only input or front and rear together input" , i have it on front only. |
#12 |
Tiny Giant Clothing
#13 |
so do you think that this would be a better bet??
MTX 1-Channel Car Amplifier (TC3001)
#14 |
that mtx amp should work fine, but if sub is a single 4 ohm you would be best off with a 2 channel amp.
| Cutting bumpstops on Tein springs... | Smokey159 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 10-30-2008 12:27 PM |
| FS: Custom Amp/Sub box for liftback!!!!!!! | ism3t | Items for Sale by private party | 5 | 09-25-2007 06:23 AM |
| Yaris 06 H/B Engine Cutting out problem.. | Farenheit | General Yaris / Vitz Discussion | 3 | 09-14-2007 01:21 PM |
