Old 12-29-2008, 10:54 PM   #1
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
Yaris T-Sport is offline   Reply With Quote
Old 12-29-2008, 11:27 PM   #2
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
Originally Posted by Yaris T-Sport View Post
Ok my oil dipstick is broken inside my engine while I installed my S"C (about 2 inches long) I remove the tube but the broken pieces is no where to be seen, may have been all the way down to the oil pan, I have been driving the car for 4 days now with out any problems, will it reach the moving parts and damage the engine?
it probably won't, but you should use a magentic rod and try to suck it back up............
otherwise you should get professional work
Yawesh is offline   Reply With Quote
Old 12-29-2008, 11:32 PM   #3
gid
Drives: '08 Yaris sedan , '08 Liftback
did you try draining the oil and then pour in a cheap oil to reflush ? Hope you have better luck .
gid is offline   Reply With Quote
Old 12-29-2008, 11:38 PM   #4
gid
I've seen so much tarnish on these ( sign of no or very few oil changes ) and wrong sized dipsticks in quite a few used older SCION XBs ( cousin of YARIS ) that are /were for sale at small and large dealerships , including TOYOTA . Should have metal like in the YARIS sedan .
Old 12-29-2008, 11:39 PM   #5
gid
I'd say don't wait due to the consequences . Better to be safe than sorry . Few hundred dollars lost better than thousands .
Old 12-29-2008, 11:41 PM   #6
gid
use WAL-MARTS cheap regular or synthetic . Some people swear by it .
Old 12-29-2008, 11:53 PM   #7
gid
dropping the pan be best , that's if you have the knowledge and nerve . Changing the oil filter several times and look inside to see if any particles . May want to pour oil from one pan / bucket to another using screen ( metal , nylon that used for window and doors ) and cover it so can capture any pieces for examination .
Old 12-30-2008, 12:08 AM   #8
gid
Some swear by their oil filters as well . Seen a woman with SUPERTECH oil filter and 5 gallon jug of regular PENNZOIL oil .
Old 12-30-2008, 12:12 AM   #9
gid
the broken piece is about 2 inches long, it is not chopped up by the engine, other wise my engine would already been dead
still would help capture all / part of it for observation if drained from pan . Trying my best to help out . New one to me .
Old 12-30-2008, 12:13 AM   #10
gid
may find it in oil filter sooner or later .
Old 12-30-2008, 12:22 AM   #11
gid
I do hope for the best of luck to you . You could take it to trust worthy garage / mechanic for advice or even have them remove pan . Shouldn't be all that much if you supply the oil , filter , and gasket . Just pay for the labor and would be under warranty . Probably be less than $125 for parts and labor . Better than engine possibly taking a crap .
Old 12-30-2008, 01:04 AM   #12
caveatipse
Drives: 2007 Black Yaris
Careful. I talked about changing to a metal dipstick and got harrassed and beaten to a pulp, and banned. You doit, and you are a hero. Do you not all see the hypocrisy??
caveatipse is offline   Reply With Quote
Old 12-30-2008, 02:11 AM   #13
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Really?? you must post Negative warnings in all the posts? See, what you are currently doing is called Trolling.... Baiting people to respond to you, such as what you got me to do here.
It's been brought up by another member, all you had to do was shut up.
No need to respond, my last comment about such topic.
Old 12-30-2008, 02:26 AM   #14
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
You could probably fish it out or flush it out through the drain plug. It's plastic so it would flush out. The sooner you do it the better. If it breaks up into little pieces, it could block oil from flowing through your engine. That would be the end of your engine.
Old 12-30-2008, 04:34 PM   #15
b_hickman11
Drives: 08 Sedan
Not all Sedans have a metal dip stick. My 08 Sedan is metal but my 07 Sedan is yellow plastic.
Old 12-30-2008, 11:11 PM   #16
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
Mine has a metal dipstick, and it's a liftback.
Old 12-31-2008, 03:35 PM   #17
rningonfumes
Yaris-T Sport,
Not to beat a dead horse.... Why did you censor your self in your first post? You had a legitimate question. Don't let trolls affect your posts.
It seems we've gone off topic too with the plastic vs steel dipstick.
Old 12-31-2008, 04:35 PM   #18
YarisSedan
Drives: 08 Yaris Sedan
If your worried just buy a tube of silicon and drop the pan. It takes like 5-10 minutes to do. Last time i looked there were about 5-10 bolts probally 10 mm. Remove it and check for debri. THe pieces are going to be big i dont think they will make it through the oil pump strainer. And then when your in there you can clean the bottom of the oil pan put a small bead of oil pan gasket sealer around the pan put it back together and let it dry for a few hours before filling with oil.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
