Old 01-01-2009, 11:27 PM   #1
bear4
Drives: 2007 yaris
Oil consumption
Hi,
We recently bought a used 2007 Yaris sedan which is overall a great car. However, on our first long highway trip from Florida to Canada (20hrs non-stop driving over 70MPH and then back - 2800 miles total) I noticed that the oil level dropped about 1/4''. We had this car for 5 months and it did not use any oil at all in normal city driving - I already went through 2 oil changes. So this oil level drop got me a little alarmed - is this normal for a Yaris? Does anybody experience the same driving at high speeds for extended periods of time? It has 72,000 miles on it.
Thank you!
bear4 is offline   Reply With Quote
Old 01-02-2009, 12:05 AM   #2
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
Originally Posted by bear4 View Post
Hi,
Thank you!
if you look at the manual, it says it will burn oil - especially a new engine - it should burn 1 quart(i believe)during 600 miles, but if it burns more than that, than seek help
Yawesh is offline   Reply With Quote
Old 01-02-2009, 12:50 AM   #3
floydisrock
73 Centurion droptop 455
floydisrock's Avatar
Drives: 2009 S Sedan
Some oils seem to disappear from the crank case more than others.
I might try a different brand of oil.
"THIS SITE HAS BEEN HACKED BY www.bimmerfest.com. YOU FUCKERS!"
floydisrock is offline   Reply With Quote
Old 01-02-2009, 03:01 AM   #4
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
My previous car would consume oil with constant high speed driving and not with just city driving. It had over 80,000 miles. I think it is normal as engine wear.
Old 01-02-2009, 03:04 AM   #5
indyfora
Wow. Mine is nowhere near that. Personally I would take it in to the dealer. one quart every 600 miles?? That would mean that in less than a month, all of your oil would be gone. Are you sure about that?
indyfora is offline   Reply With Quote
Old 01-02-2009, 04:17 AM   #6
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
As your oil darkens and ages, it'll eventually start to burn. If you check the oil and it's jet black, then you can bet you've burned way too much so it'll drain less than the full 4-quarts on the change. That means you gotta change your oil right away, otherwise your pistons will seize-up and you'll be out shopping for a new engine real soon.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
