Old 01-05-2009, 06:42 AM   #1
mastaofdisasta
mastaofdisasta's Avatar
Drives: yaris
urGENT. need halp!!!!PLX
So im hooking up my system and ive had the same prob wih 2 amps. I turn the car on, and the light on the amp flashes for a slplit second and then goes off. Then when i trun the key off, it flashes again for a split second. Ive tried everything, i think maybe its a ground ima try to sand down the ground area and then retry it....can anyone else help. Its a pioneer760 peak watt amp and 800w peak sub. THANKS
btw ive been at this project for 6 hours now and its almost 2 am im runnning on Monster and Marlboro excuse the typos
ballin on a budget.
mastaofdisasta is offline   Reply With Quote
Old 01-05-2009, 07:01 AM   #2
coheed
Drives: 08 BB LB
It might be your "remote" power, the one you wire to the ignition. Could be the ignition being in a certian position it sparks. Could be worth a check.
Old 01-05-2009, 07:17 AM   #3
mastaofdisasta
Drives: yaris
got a better ground now and we be hittin up in this beotch (that means the sub is workin)
woot 3 more hours and ill be done, 3 hours before i have to be at work
i miss my accord where everythng was held in by one or two bolts instrad of 50,000mini plastic clips
ballin on a budget.
URGENT help needed :( -DIY springs Masteraal DIY / Maintenance / Service 19 12-23-2008 03:23 AM
how can u test a sub? URGENT Sway84 In Car Entertainment + Electronics (audio / video / alarm) 10 07-09-2007 02:16 PM
urgent info needed..(before going shopping) seanele Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 07-02-2007 10:07 PM
URGENT - CAPACITOR QUESTION SeriousBlack In Car Entertainment + Electronics (audio / video / alarm) 6 06-25-2007 09:27 PM
Urgent! Driving to Yellowstone from Northern Utah hans_fh General Yaris / Vitz Discussion 1 05-16-2007 03:06 AM
