Old 01-15-2009, 02:41 PM   #1
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
why is one side of oil dipstick different from otherside?
i read the lower side because it's not "smeared" up
the higher side is always smeared across the high "dot"
i guess it's because the dipstick curves through the tube, so one side is inaccurate?
Yawesh is offline   Reply With Quote
Old 01-15-2009, 04:39 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
You are correct. Since its curved it scrapes as it goes down and up. I always flip the dipstick and take the lowest reading. Nissans especially infinitys really have this problem the worse. My shop we never use the dipstick to check the level on those cars. If you put in 3 quarts of oil and then check the level it will look like the car has 6 quarts of oil. Even though its still low. You have the let the car sit for a very long time till all the oil settles and then check it slowly.
Old 01-15-2009, 05:10 PM   #3
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
thanks friend
Old 01-16-2009, 07:52 PM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
What ever happend to the crosshatch and "L" and "H" indicators on the dipstick...
Now it's just 2 dots one near the bottom, one about an inch above that.
Does the top dot mean enough oil and bottom dot mean low?
Old 01-17-2009, 11:04 AM   #5
TheSilkySmooth
TheSilkySmooth's Avatar
I dont trust the dipstick too much - it is often hard to find a level area for an accurate cold reading anyway. I just ensure that all oil is drained during and OC by jacking the car in various angles whilst draining. Then I put in 3.5 litres since the other 200-300ML stay in the engine in the cam box and galleries and betwixt the pistons, etc. I gladly notice no oil loss through the 4500 mile interval therefore no need to worry about topping off unless I wish to to fortify the oil for the last 1000 miles of the oil life interval. I do promote this practice of topping off at say 3500 miles to get some good stuff back into the oil sump, since the good stuff tends to get used up throughout the interval. If you dont burn off oil in the time span, I might suggest you should drain off the requisite 1/2 litre you had reserved from the initial sump fill for top off and replenishment. Good driving to all!
-Papa
Old 01-17-2009, 11:57 AM   #6
Treyz
~ ambient one ~
Treyz's Avatar
Don't you guys in the 08's and up have the metal stick?
I have the ol' plastic.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 01-17-2009, 02:30 PM   #7
detroiter
detroiter's Avatar
My 08 has metal dipstick and my gf's 07 has the plastic one.
Old 01-19-2009, 01:41 PM   #8
TheSilkySmooth
The family '08 3dr has metal dipschtick
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
Which side of engine oil dipstick do you read ? Yawesh General Yaris / Vitz Discussion 11 01-08-2009 04:43 PM
Broken Oil Dipstick Yaris T-Sport General Yaris / Vitz Discussion 23 01-01-2009 08:39 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 05:27 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
