Old 01-19-2009, 02:48 PM   #1
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
How to change brake pads?
Is there a DIY on changing break pads front and back? also how to bleed the breaks?
Red Horse is offline   Reply With Quote
Old 01-19-2009, 02:56 PM   #2
ChinoCharles
Drives: LB
http://www.yarisworld.com/forums/showthread.php?t=4530
Never changed the brake shoes yet, but that will help with the pads.
Old 01-19-2009, 03:54 PM   #3
Red Horse
Red Horse's Avatar
Wow!! this is great thank you.
Old 01-19-2009, 03:58 PM   #4
ChinoCharles
Drives: LB
No problem-o, thats what we do.
Old 01-19-2009, 09:10 PM   #5
Klink10
Klink10's Avatar
There are numerous ways to "bleed brakes". You can do a google search and come up with them. Having just done mine I used them all, from pump in (Motive) to pump out (MityVac). The best results (for me) were obtained using the old fashioned 2 person method. Patience is a key word during this procedure.
Old 01-19-2009, 09:22 PM   #6
jkuchta
Drives: 2007 Yaris hatch (red)
I founf best results using a friend to help bleed the brakes as well. You might use a little more fluid, but it's worth the results.
jkuchta is offline   Reply With Quote
Old 01-19-2009, 11:55 PM   #7
auxmike
auxmike's Avatar
You've gone through your brakes already??
Old 01-20-2009, 10:02 PM   #8
cfiimei
Drives: Sedan
Don't bleed them unless you somehow open the system...
cfiimei is offline   Reply With Quote
Old 01-20-2009, 10:06 PM   #9
Klink10
Klink10's Avatar
In my case no. I just had the calipers powdercoated which required they be re-built and bled.
Old 01-20-2009, 10:38 PM   #10
jkuchta
You need to open the system to change out the rear shoes, and cracking the bleeders on the front makes dropping in new pads much easier. I was changing the fluid out also, so it just made the whole operation much easier.
I didn't NEED to change pads and shoes, but wanted to when I took the car to the track. The front pads looked brand new after 35,XXX miles, and the rear shoes looked pretty much untouched too.
As for changing out the rear shoes, the online manual that's sticky'ed above has the step-by-step, and it's relatively easy. The hard part is getting the main spring on and off. Other than that it's pretty straight forward. It took me an hour to do one side, and about 20 min. to do the other (first time I'd ever changed out drum shoes).
Old 01-29-2009, 07:45 PM   #11
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Hey guys, what are you guys using as replacements? OEM from the dealor? Any aftermarket sources? I'm about due. At 25k, the right is squeaking. When I take the wheels off to inspect, I want to be able to do them if I see that I'll need to.
Old 09-16-2011, 12:58 PM   #12
nvidiaxtc
nvidiaxtc's Avatar
Drives: Black 2009 3Dr Hatch
Having trouble with this old link.
nvidiaxtc is offline   Reply With Quote
Old 09-24-2011, 02:31 AM   #13
YarisLover09
Drives: 2009 Yaris Hatchback
I am also having problems with finding where this link has been moved to...
YarisLover09 is offline   Reply With Quote
Old 09-24-2011, 12:14 PM   #14
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Link is forever gone. It might be posted on microimage forums.
Old 09-24-2011, 05:08 PM   #15
YarisLover09
I see. Thank you.
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 05:23 PM
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS kargoboy YarisUniverse 11 01-20-2009 04:43 PM
First thoughts: Carbotech XP8 pads and slotted rotors jkuchta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 12-19-2008 10:21 AM
ichi ban brake pads Kitt Central and South America 13 10-30-2008 03:12 PM
