Old 02-01-2009, 03:26 AM   #1
phenoyz
phenoyz's Avatar
Drives: yaris
lowering springs
which has overall better quality lowering springs:
TRD, tanabe or tein?
cornering, ride comfort, durability
plan to lower soon
phenoyz is offline   Reply With Quote
Old 02-01-2009, 09:23 AM   #2
durability, im sure theyll all be the same since youre somewhere warm. however, the lower the drop, the quicker itll wear out your stock shocks/struts.
comfort...i believe that TRD uses progressive spring rates, so the more theyre compressed, the firmer then get...so theyll feel most like stock until you push the car
cornering is hard to say...depends on how hard you drive. imo, the tanabe df's and the teins are pretty soft especially for how low they drop. so if you turn hard and hit a bump, youre more likely to hit a bumpstop vs the ride height on the TRD's
Old 02-01-2009, 07:41 PM   #3
I don't have a problem with cornering with the S.Tech's, but I'll tell you know that the TRD's are most likely more comfortable than they are. My family and friends complain all of the time about the ride quality (I want it stiffer tho).
Old 02-04-2009, 11:33 PM   #4
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
I ran Tanabe's for a few months, switched to TRD's and haven't look back! The car sits fractionally higher with the TRD's but you really can't tell. I like the ride better and the TRD's are progressive. No problem with ride quality and no complaints from my family members. I'm still running stock shocks.
My vote is for the TRD's.
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 02-05-2009, 03:37 AM   #5
phenoyz
phenoyz's Avatar
Drives: yaris
trd springs
what kind of tanabe did you have b4?
ust got mine rpf1 15,(wanted the lightweight)
probably gonna get trd too
Old 02-05-2009, 10:01 AM   #6
Herbicidal
Herbicidal's Avatar
I had the DF210's. No matter what springs you go with, make sure to get an alignment about a week after the install.
Old 02-07-2009, 10:56 PM   #7
SEVEN
Drives: 07' HB Black
Most comments are tanabe vs. trd ... anyone has tried both trd and tein???? cus' I have TRD and I like it a lot .. but I'm looking for lower and stiffer ... are tein springs the one for me or not???
When life passes you by ... dowshift
SEVEN is offline   Reply With Quote
Old 02-07-2009, 11:56 PM   #8
Yeah, the Tein S.Tech's are most likely stiffer than the TRD's (not sure what the spring rate on those are since they are progressive, and I don't feel like googling right now). If I remember correctly, the S.Tech's are 3.0kg in the front and 3.5kg in the rear. It's also almost twice the drop of the TRD's, but for PR, I'm going to assume you'd want to stray away from being that low (from what members here say).
Old 02-08-2009, 08:53 PM   #9
SEVEN
Definitely!! cus' most of the streets here suck ... your government gives our government a whole lot of money so we that we get streets as good as yours .. but our sucky government takes most of the money and puts it in their pockets and we get ... THE WORST STREETS EVAH!!!
still ... I HEART LOW CARS!!! I'll probably get the teins if I confirm that the teins are stiffer than the trds
Old 02-09-2009, 11:59 AM   #10
Nagoya_TRD.
Drives: None.
I hear the tanabes have pretty good ride quality. Maybe not as stiff, but better on the street. Not sure about the S.Techs
Nagoya_TRD. is offline   Reply With Quote
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
tanabe or trd or ???? ROCKLAND TOYOTA Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 09-11-2007 12:14 AM
TRD Sportivo with Tanabe NF210's and cut bump stops? Jerkratt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 07-16-2007 08:21 AM
Tein S.Tech, TRD shocks, Tanabe strut bar review Kaotic Lazagna Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 04-16-2007 12:41 AM
tanabe or trd wushumasterku Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 12-23-2006 09:24 AM
