Old 02-15-2009, 10:03 PM   #1
Niko
Drives: 2008 toyota yaris sedan
just put in cold air. Need help
I just put an intake in my yaris. it is a 2008 sedan. when i am driving my check engine light turns on, is there something i can do? i treid unplugging the negitive battery cable and it turns it off but afterwords when i drive for a minute the light turns back on. Also when i am driving the car shifts late.
Niko is offline   Reply With Quote
Old 02-15-2009, 10:05 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
sounds like you forgot to plug something in. double check your hoses and plugs
Old 02-15-2009, 10:12 PM   #3
Niko
i checked over it everything seems to be fine. my dad said that i might need i different mass airflow sensor????
Old 02-15-2009, 10:13 PM   #4
Niko
would it do that if there was a leak in the tube?
Old 02-15-2009, 10:14 PM   #5
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Yes... Also, is the intake tube the correct diameter?
Old 02-15-2009, 10:21 PM   #6
Niko
the tube i put on is a three inch tube. the original tubeing was i think a two
Old 02-15-2009, 10:22 PM   #7
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
thats the issue. the maf housing you used it too large.
Old 02-15-2009, 10:32 PM   #8
Niko
so i should move to a two inch intake?
Old 02-15-2009, 10:33 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
would that cause a CEL so quickly?
Old 02-15-2009, 10:34 PM   #10
Niko
? i dont understand?
Old 02-15-2009, 10:40 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
mass airflow sensor works by "measuring" the velocity and temperature of air that passes past the sensor. if you change from a 2" to a 3" pipe the MAF measures X amount of air and is actually receiving 30% more air. not sure that it would cause a CEL that quickly that's why i asked if you'd wired everything correctly.
Old 02-16-2009, 12:04 AM   #12
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Since the tube is wider, I assume that the same amount of air that the engine consumes is moving slower past the MAF sensor. That may skew the temperature that is being sensed.
Old 02-16-2009, 02:13 AM   #13
Niko
well i went to check like you said and i found that it was a number of air leaks that were causing the sensor to not read correctly. I used a sealent to fix the leaks and just got back from i two hour drive and the car ran great and no check engine light.
Old 02-16-2009, 02:15 AM   #14
Niko
thanks for the info guys. i really have no where else to go to get help for my yaris because my family is an american car family.
Old 02-16-2009, 02:35 AM   #15
mikenacarato
SIPNDEW
Drives: 15 STI
the tube size is wrong. ive tried doing the same thing on my car before i got the trd intake. the car would barley idle and it threw a CEL almost immediately.
Old 02-16-2009, 12:01 PM   #16
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
If you get the CEl again you need to change to one of the many proven intakes out there.
AFE, AEM, Simota, Fujita, WR.
Old 02-16-2009, 12:07 PM   #17
15 replies and nobody has yet asked "What CAI did you install?"
3 inch tube, I'm guessing ebay noname. With incorrect tube diameter you are definitely asking for a CEL to be thrown.
Old 02-16-2009, 03:21 PM   #18
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
lol THIS^^^^
Simota Carbon Charger Cold Air Intake lilredrocket Performance Modifications 18 04-13-2009 03:16 AM
guess what I'm waiting for and how much I paid? Ric n Sov's Vitz RS General Yaris / Vitz Discussion 27 06-27-2007 07:36 PM
problem with cold air intake skc Canada 24 06-18-2007 07:34 PM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 04:25 PM
