Old 02-25-2009, 10:54 PM   #1
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
DRL Disabled If I Install HIDs?
First, I did my search beforehand and nothing related to this topic came up, so I decided to post one for myself and for future references.
Up here in Canada, DRL (Daytime Running Light) is mandatory and illegal without them. That being said, I am wondering how to solve this problem as I decided HIDs to be my next upcoming modification.
I am planning to purchase one of those H4 Hi/Lo conversion kits (right at this point I will put my flamesuit on just in case) but I'd like to find out some info about solving DRL problem before I make up my mind.
Any info will be appreciated, thanks!
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 02-25-2009, 11:02 PM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
having DRLs can and may lead to premature failure of the HID kit.
Old 02-25-2009, 11:21 PM   #3
ae92trueno7
ae92trueno7's Avatar
Drives: 2007 Yaris Supercharged
there is a drl ecu right underneath ur ignition cylinder... u can just disconnect that connector..... make sure after its disconnected that ur headlights are working properly...
ae92trueno7 is offline   Reply With Quote
Old 02-25-2009, 11:22 PM   #4
mikenacarato
SIPNDEW
Drives: 15 STI
how are you going to get around the DRL elimination being illegal?
Old 02-25-2009, 11:25 PM   #5
ae92trueno7
yah it is illegal not to have drl in canada.... i have my stane alone fog lights...
so i turn my fogs on as my drl...
Old 02-25-2009, 11:29 PM   #6
ae92trueno7
darkmoon id ur having troubles looking for that drl ecu... the DIY explains the steps pretty clear...
Old 02-26-2009, 07:41 AM   #7
Castaway
Drives: 2008 Yaris hb 2d
In Canada, no new car can be sold without DRL, but AFAIK it's not illegal to disable them.
Castaway is offline   Reply With Quote
Old 02-26-2009, 08:08 AM   #8
Jerkratt
Jerkratt's Avatar
they have digital ballasts now... cause my friend has a charger and i went to my buddy and got a set of plug n play eagle eye hid's and he told me that i dont have to disable the drl's and they work so.. if u need more info ill call my buddy who is the owner of a sound/rim shop
"It hurts more when its wet"
Old 02-26-2009, 09:34 AM   #9
the yaris' DRL do not supply enough current, so they strobe. To fix the issue use a relay to directly connect the HID to the battery.
Many higher class luxury car use their HID as DRL. There shouldn't be a problem using the HID as DRL.
http://cgi.ebay.ca/HID-FUSE-RELAY-HA...3A1|240%3A1318
Where is my DRL Module......? Help With HID's The Architect DIY / Maintenance / Service 6 05-20-2009 10:21 AM
DRL and HID's? dimsum69 Cosmetic Modifications (Exterior/Interior) 5 01-12-2009 03:30 PM
where can i install these power locks? songa New England 1 12-04-2008 12:41 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
DRL enabled with HIDs... sort of... Galavoxx Cosmetic Modifications (Exterior/Interior) 0 03-28-2007 08:26 PM
