Old 03-16-2009, 03:21 PM   #1
lbm323
Drives: yaris
LIGHTS
both my lights went out. one day they just didnt work. i checked the fuses and they are all fine. the high beams still work though but when i turn them on the high beam indicator does not turn on. could it be the bulbs or something electric that went wrong?
lbm323 is offline   Reply With Quote
Old 03-16-2009, 03:30 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
you got separate fuse for low beam.
Old 03-16-2009, 04:16 PM   #3
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
WARRANTY, the dealer could use it.......
Old 03-16-2009, 05:04 PM   #4
I think that the High Beam indicator being out is the key:
The High Beam indicator light gets power, whether the bulb filament is open or closed.
The 10A fuse (1:H-LP LH/H-LP LO LH) in the under-hood fuse box is the feed to it, as well as to the left side high/low beam filaments.
Check that fuse, although if it were bad, on the left, both high and low beam would be out...
Its ground path is through the ED contact on the Headlight Dimmer Switch (the stalk). I would suspect it (the headlight dimmer switch) as being the most likely cause of the issue.
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
LED rear lights question Danish Yaris Cosmetic Modifications (Exterior/Interior) 24 04-16-2009 02:26 PM
CLUSTER LIGHTS WENT OUT Go4th DIY / Maintenance / Service 23 01-25-2007 11:37 AM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
