Old 03-17-2009, 05:59 PM   #1
revoturbo
revoturbo's Avatar
Drives: yaris
FINAL GEAR 3.7 yaris
any info ...?
yaris Turbo/SC with final gear 3,7 (original 4.3)..
multimakmurperformance.com
revoturbo is offline   Reply With Quote
Old 03-17-2009, 06:08 PM   #2
What is the question?
Old 03-17-2009, 06:44 PM   #3
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
Originally Posted by revoturbo View Post
any info ...?
Apa Kabar?
Where in indonesia are you? I used to live there years ago.
I believe he is asking if the final gear is 3.7 in the turbo yaris. Instead of the 4.3 final gear found in the other models...
The C54 transmission found in the 1.5l yaris has a final gear of 3.5
The Scion xA transmission (which is also a 1nzfe) has 4.3
The Yaris YR 1.3l 2NZFE has 3.9
The C160N 6 speed from the levin is 4.5
hope that helps....
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 03-17-2009, 06:52 PM   #4
I want a 6 speed
Old 03-17-2009, 08:08 PM   #5
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
OK,
The US Yaris comes with the C50 tranny and its highway friendly 3.722 Final gear
The Yaris TS, and not sure if other Asian spec Yaris have the C56 tranny which indeed has a Final gear of 4.312
Is just that there are 2 different 5spd transmissions used on the second gen yaris around the world.
Revoturbo you should be able to determine wich tranny do you have in your car by looking at the badge on the drivers door... where the chasis number is.
It should say either C50 or C56 somewhere in that badge.
Old 03-17-2009, 08:11 PM   #6
CASTREX
CASTREX's Avatar
I want a 6 speed
You could import a 2009 TS
You would have 6 speed + 300 extra cc of displacement that will be of great help spooling a T28 turbine...
Old 03-17-2009, 09:46 PM   #7
ok, will you set that up for me?
Old 03-19-2009, 12:43 AM   #8
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
3.7 will be better for the turbo cars.
Old 03-19-2009, 01:02 AM   #9
dallas
Drives: Yaris Hatch /Landrover D2
Someone should swap in a unit from the XA and watch their acceleration improve. I bet that gear change in the final drive is worth 3 tenths in the quarter mile.
dallas is offline   Reply With Quote
Old 03-19-2009, 11:33 AM   #10
revoturbo
revoturbo's Avatar
Drives: yaris
just got info from my friend (yaris club)
Yaris standard final gear 4.3
shift @ RPM 6500
1st gear 54 Km/H
2nd gear 88 Km/H
3rd gear 118 Km/H
4th gear 162 Km/H
5th gear 208 Km/H
Final gear 3,7 (yaris turbo M)
shift @ RPM 6500
1st gear 62 Km/H
2nd gear 103 Km/H
3rd gear 138 Km/H
4th gear 185 Km/H
5th gear 230 Km/H
Final gear ratio= starlet turbo EP 82 .4EFTE
this final gear 3,7 is a must for yaris with Turbo/ SC right.?.
Old 03-19-2009, 11:41 AM   #11
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
already done by a member here in california.....
Old 03-19-2009, 04:40 PM   #12
CASTREX
CASTREX's Avatar
The question for that answer really depends on what you want your car for...
For a NA there is no doubt that it would benefit from the shorter gear ratio.
However for a turbo Yaris the longer gears will probably be better at least for street use...
Old 04-26-2009, 04:32 AM   #13
Morgan
Morgan's Avatar
Drives: 07 MM LB
The 04-06 Scion xAs and xBs have a shorter gears, so with an NA car looking to pick up speed from 0-60 that final drive is better. Be warned that a scion transmission will not fit into a Yaris (06+), however I did not try to swap the gear sets - thats a whole other project
If you do swap those Scion gears in, be sure to keep us updated! (You might even be able to sell off your old tall gears to a Scion owner who wants better mileage)
Old 04-26-2009, 09:01 AM   #14
revoturbo
revoturbo's Avatar
Drives: yaris
Yes thank You. I got the final gear last week (3,7)
Old 04-26-2009, 09:12 AM   #15
Actually... not really... Our cars here have the same short 4.3 gears, and the problem is, to reach 60MPH we need to shift into 3rd, wasting valuable time compared to you guys who can reach it right at the end of 2nd... So while you guys can do 0-60 in about 8-9s, it takes us over 10...
Though in an autocross/track environment the shorter gears would be an advantage....
Old 04-26-2009, 09:28 AM   #16
revoturbo
revoturbo's Avatar
Drives: yaris
Toyota starlet Gt turbo has 3,7 too.
Which Redline gear oil is the best for our Yaris? stevencyt DIY / Maintenance / Service 0 03-13-2007 11:11 PM
