Old 03-27-2009, 09:28 PM   #1
MicroHB
Drives: MY HB
Alignment help :(
Just got my alignment dot at a local shop
I got coilover and camber bolts installed.
So i drop the car off to get it aligned and i get a call from the shop saying my toe is fine but my camber is off and not "correctable"
front left side front right
-1.8 -3.5!
can someone explain?? he said he was unable to adjust anything and charged me $50 for his time
this is the kit i got on the car now
http://shop.microimageonline.com/pro...4&productId=72
MicroHB is offline   Reply With Quote
Old 03-27-2009, 09:31 PM   #2
supmet
Drives: 2007 4 Door Yaris
Did you tell the mechanic you bought ADJUSTABLE camber bolts?
Also, -3.5 is farther than the bolts list they go on the microimage site. 15mm Adjustable Camber Bolts +/- 1.75 degrees. Did you hit a curb or something? You might have broken a bolt?
Old 03-27-2009, 09:35 PM   #3
MicroHB
Drives: MY HB
i did he said to contact the manufacture and i did not hit anything he blamed it on my coilovers
Old 03-27-2009, 09:44 PM   #4
1NZYaris1
1NZYaris1's Avatar
What incorrect instalation , .
Old 03-27-2009, 09:51 PM   #5
YarisSedan
Drives: 08 Yaris Sedan
What kind of alignment machine is he using the kind where you still have the comp the heads or the laser kind. Maybe the guys a idiot and dosnt have the adaptors installed on your wheels correctly.
Old 03-27-2009, 09:51 PM   #6
MicroHB
Drives: MY HB
are you saying my coilovers are installed incorrectly?
Old 03-27-2009, 09:52 PM   #7
MicroHB
Drives: MY HB
he said its laser machine i didnt see the shop area
Old 03-27-2009, 09:54 PM   #8
1NZYaris1
1NZYaris1's Avatar
Sounds that way , or the guy doesn't know what he is doing ,
ie camber bolts required to correct problem .
Old 03-27-2009, 10:05 PM   #9
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Explanation: You need to take your car to a more performance-oriented alignment shop.
Better yet, just do your own alignment. There's nothing to adjust in the rear, and only two simple adjustments to make in the front.
Invest in a cheap construction level to check camber. Roughly 1 degree of camber for each 1/4" the top of the wheel is in more than the bottom of the wheel... you can do some trig if you want to be more accurate, but what's most important is that you're even from left-to-right. Within 1/4 degree is plenty close enough.
Check toe with a tape measure. Getting zero toe is easy, measure from tread-groove to tread-groove on the front side of the tire and the back side of the tire. If the measurement is the same, you're at zero. Ideally, you'll want maybe 1/16-1/8" of toe-in.
All you need is a level driveway or garage, some common hand tools, and a little patience.
Oh, and if you have a proper coilover kit, you shouldn't need camber bolts. The lower hub mounting bolt hole should be slotted for adjustment.
Old 03-27-2009, 10:17 PM   #10
MicroHB
Drives: MY HB
I ended up buying a D2 coilover kit thanks for the help he got my toe to 0.10 degrees on bth sides caster is at -5.5 on the left and 5.3 on the right
Old 03-27-2009, 11:18 PM   #11
Loren
What?
Loren's Avatar
Caster is non-adjustable on the Yaris, so you can't credit your alignment tech for that. It is what it is.
Old 03-27-2009, 11:27 PM   #12
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
I don't get what happened with this outcome...you bought another set of coilovers?
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 03-27-2009, 11:32 PM   #13
MicroHB
Drives: MY HB
i bought D2 coilovers and camber bolts went in to get aligment and this is the result
Old 03-27-2009, 11:35 PM   #14
Shroomster
Shroomster's Avatar
sooo you got the idiot who told you he couldn't align the car in the first place to align it anyways?
Old 03-27-2009, 11:41 PM   #15
MicroHB
Drives: MY HB
no he told me that after he "did the job and dedicated his time"
Old 03-27-2009, 11:44 PM   #16
Shroomster
Shroomster's Avatar
well the car is driving straight and you now have a better handling yaris...so hey
Old 03-27-2009, 11:47 PM   #17
MicroHB
Drives: MY HB
driving straight
yes
no that's the purpose of this thread to see what can i do now
Old 03-28-2009, 09:34 AM   #18
Loren
What?
Loren's Avatar
Um... you didn't really ask "what you can do", you asked for an "explanation". The explanation is that your alignment tech is afraid of aftermarket parts. Doesn't understand them, doesn't want to.
As I said last night, find a shop that is more performance oriented or just do it yourself. Take the wheel off, loosen the two strut-to-hub mounting bolts and see what you can do with it. Check your strut assembly and see if it has slotted holes like it should. If it does, I'd put stock bolts back in rather than the (thinner and weaker) camber bolts.
Unless something is bent, you should be able to get both sides to the same amount of camber.
How soon to get alignment after TRD spring install? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 03-24-2009 08:08 AM
Dealership explains no need for alignment jmjonesey DIY / Maintenance / Service 6 04-23-2007 04:20 PM
Suspension alignment after new springs? mrrock Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 02-14-2007 01:05 PM
Wheel Alignment Data Asif Kazani Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-22-2007 12:48 AM
Front End Alignment after Spring Install? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-26-2006 07:46 PM
