Old 09-03-2006, 08:07 AM   #1
oscarying
Drives: SLOOWZ
Questions about springs
Would like to ask ..
is that changing the springs but not changing the whole suspension would shorten the life of the factory damper?
how long will that be shorten if thats true?
i wanna get kings spring due to its cheap in aust
oscarying is offline   Reply With Quote
Old 09-03-2006, 12:27 PM   #2
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
You can get Tanabe springs from Jay at C2AUTO or P.M. him at C2AUTOSPL. Dont know about the shipping though. Tanabe states that their springs are fine with the stock shocks and struts. I am sure it will wear a little faster depending on how far you go down, but I would be sure to get the front end aligned or checked after lowering to make sure every thing is ok.
Old 09-03-2006, 07:16 PM   #3
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
Lowering springs on stock shocks/struts will shorter thier life by the half.
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 09-03-2006, 08:16 PM   #4
BulletProofAuto
Drives: 00 itr
there is no direct amount that the springs will shorten the life of dampers. i would not worry about it too much though, by the time your stock dampers begin to fail there should be plenty of "improvements" on the market to replace them with.
BulletProofAuto is offline   Reply With Quote
Old 09-03-2006, 09:57 PM   #5
slvryaris
slvryaris's Avatar
I imagine the stock shocks/struts wouldnt last that long in the first place.
Old 09-04-2006, 10:01 AM   #6
03Z33
03Z33's Avatar
Drives: TCR10
I can't say how long they'll last, but they do get VERY hot after a session at the track running R-compounds ! As mentioned, the Tanabe springs aren't so much stiffer than stock to cause "excessive" stress to the shock/struts... For normal street driving they should last a few years before any major signs of wear.
03Z33 is offline   Reply With Quote
Old 09-04-2006, 12:57 PM   #7
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Talked to Tanabe direct a few times already... their DF210's were designed to use the stock struts/springs, and factory sway bar end links.
Now you can always improve on the factory stuff, and get a much better upgrade, but its not needed.
Old 09-05-2006, 07:29 PM   #8
oscarying
Drives: SLOOWZ
For the DF210's you guys mentioned,will it drop the baby?
Old 09-05-2006, 07:32 PM   #9
Chris07LB
Chris07LB's Avatar
The SEARCH button is your friend. Lots of posted info and pictures of the DF210's. Go have a good read.
Old 09-05-2006, 10:39 PM   #10
bulldogs2k
bulldogs2k's Avatar
Drives: '00 s2000, 2007 yaris hatch
happy motoring!
bulldogs2k is offline   Reply With Quote
TANABE SPRINGS C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 11-20-2008 07:38 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
TANABE DF210 SPRINGS AVAILABLE!!! C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 08-05-2006 12:28 AM
FS: Spirit Lowering Springs 1.7" drop xCookiE Items for Sale by private party 2 07-24-2006 08:29 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
